Thread: Column height at pool compared to porch
    Jun 2013
    Huntsville AL
    107
    Hopefully this is the right place to post this. It is the very early stage of pool construction. The covered patio will eventually lead out to a 20x40 pool. I wanted to see if I could get some input on the porch columns and the covered patio/outdoor kitchen area. As can be seen in the photos the covered patio columns are a lot taller. The rear elevation looks better on the prints than the side view. Code requires the crawl space to be a minimum of 3' so the amount of steps on the back porch should be pretty accurate.
    The covered patio is coming off the garage and its 14x16. The distance between the porch and covered patio is 25'.
    IG Vinyl, 20'x40' Sports Pool, Savannah Liner no border, 20' liner steps, 2 Venturi Renegade Skimmers, Hayward 1.5hp 2 speed pump, Aqua Rite 40k Salt system, Typhoon slide, Hayward Sand Filter, 22,519 gallons, TF-100 test kit
    Jan 2011
    Richmond, Texas
    595
    Re: Column height at pool compared to porch
    Why don't you have the new columns sit on brick columns to match the height of the stairs? It is really hard to tell from the drawings but to me the new columns look way out of place.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Jun 2013
    Huntsville AL
    107
    The whole house will be new construction. Good point about making the brick columns same height as steps.
