Results 1 to 7 of 7
Thread: Screeen Enclosre on a Paver Deck with Footer....Help
    Hi, I am currently under day one of my pool enclosure construction. I have pavers and I noticed they are not anchoring the enclosure all the way through my pavers and into the footer like I thought would happen. It is only anchored with tap-cons to the pavers. Is this common practice or should the cage be anchored all the way to the footer??? I live in Fl and code is 130mph winds I believe. I guess I am wondering if they are supposed to do this, or if its just good craftsmanship when they do. Thanks for the help.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Re: Screeen Enclosre on a Paver Deck with Footer....Help
    I believe that The tap-con anchor bolt should go thru the paver into the footer.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jun 2013
    SpringHill FL
    415
    You should be anchored into your footer.
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    30,403
    That doesn't sound like good practice to me. I believe I would want a better anchor into the footer or a VERY good explanation from contractor why not.
    Dec 2013
    apollo beach,fl
    36
    That should go through the footer! Are you sure it's not? crazy if it's only thru the pavers...i bet it's thru the pavers.
    1987 16k gallons IG, Marbletire Marquis, ,Pentair superflo 1hp, Hayward s244t, Chlorine (working on stenner setup)
    They came back today and put the anchors through through to the footer. They said the short ones was only to hold in place. They put the long ones by every post. I feel better about that anyway. Thanks for all the help
    Anchors are structural. Thus are required to be "anchored" into a footer (which again is structural)
    Pavers are NON-STRUCTURAL as they only rest on the surface of whatever (concrete, sand, earth, etc).
    Will
