Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: My pool guy quit!
    Jun 2013
    Fontana California
    56
    My pool guy quit!
    My pool guy called last week to tell me he has been ill and may be forced to retire. I never know when he comes to service the pool so I am uncertain of when his last visit was and now my pool is turning green.
    I went to Leslies to have my water checked and the results are as follows:
    FAC 0
    TAC 0
    CH 290
    CYA 40
    TA 220
    pH 8.4
    Acid 4
    Copper 0
    Iron 0
    Phosphates 150
    Leslies is recommending a lot of chemicals that I believe will be well in excess of $100 and I am not sure it will even fix my problem. I tried to maintain my pool in the past using advice/tips from the experts at Leslies and was unsuccessful. I spent a ton of money and never did get my pool right.
    Please help if you can.
    I live in Fontana California.
    14K Gallon IG Gunite Pool built in 2005, Century Centurion 1 1/2 HP Pump
    Pentair Clean & Clear 420 Sqft. Cartridge filter, MiniMax Pentair NT Heater, The Pool Cleaner
    Taylor K-2005 test kit with Taylor K-1515-A FAS-DPD Chlorine Test. SpeedStir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: My pool guy quit!
    Likely all you need is some acid to get the pH down and some bleach / liquid chlorine (maybe a lot) to run through the SLAM process covered in the pool school link in the upper right. You will also need to get a good quality test kit (one of the ones suggested in pool school) to easily and successfully complete the SLAM process. Cooler weather this time of year will likely make this easier than doing it in the heat of the summer. We generally don't trust pool store "free" testing very much, but FC and pH are hard to get completely wrong.
    Ike
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    My pool guy quit!
    First thing I'm going to do is suggest you spend some time reading in pool school. Here are couple of articles to start off with.
    pool-school/pool_water_chemistry
    pool-school/types_chlorine_pool
    pool-school/shocking_your_pool
    The second thing I going to recommend is investing in one of our recommended test kits. This is the tool you will need to take control of your pool and perform the SLAM process, which your going to have to do.
    pool-school/pool_test_kit_comparison
    We can help you out but we're going to need a little help on your part to do some reading and educating yourself on our methods. Getting one of the test kits is a must have.
    Jeff
    +1 to both posts above.
    A good test kit is the best investment you can make in successfully maintaining your pool. It will save you a lot more money than you spend in getting it.
    SLAMming takes some effort, but it works every time. And once it's complete, the helpful folks here will help you understand and maintain your pool so that you don't get algae again. You may feel a little overwhelmed at first; just keep going through pool school, ask questions, and you'll have it mastered in no time.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Jan 2011
    Richmond, Texas
    595
    Don't panic. The chemistry can seem overwhelming at first, but this awesome website can get you on track for way less money. Do what they experts say above and you will come out with a sparkling pool.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    pool-school/pool_calculator
    Use that link, punch in your gallons, and get your PH lowered to mid 7 range using muriatic acid first and foremost. Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Welcome!
    First, without a proper test kit, you're working blind. You need a FAS-DPD test kit, period. Leslie's will try to sell you a DPD test kit and tell you it's the same. It isn't. It's a chunk of change, but probably less than one month service charge from the pool guy. It will pay for itself in no time.
    Second, do a little reading in Pool School, so these terms we throw at you don;t confuse you worse.
    Third, if those numbers are believable, all you need is some acid to adjust pH down to about 7.2 and then lots and lots of liquid bleach for several days running. How much? Only test results and the Pool Calculator can tell. But it can be done.
    A little inspiration:
    first-time-shocking-with-bleach-t45074.html
    pretty-black-pool-t58442.html
    first-time-pool-owner-t61565.html
    a-little-encouragement-for-those-with-algae-and-new-to-bbb-t57137.html
    frog-filled-green-swamp-to-oasis-work-in-progress-t48213-20.html
    before-and-after-t36785.html
    a-final-picture-set-of-how-well-the-bbb-method-works-t33199.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum cottielee!
    Just a word of encouragement and to second some others, this really is easier than it may first appear.
    As for learning, don't worry yourself with much more than the ABC's of pool chemistry in Pool School right now.
    You will need a test kit to control your own pool, but other than that, a little knowledge and willingness to learn is all you need.
    We like using bleach (liquid Chlorine) for maintaining Free Chlorine. You will need to adjust your pH too, but getting the FC up right now should be your first priority.
    Essential Links:
    Jun 2013
    Fontana California
    56
    Thanks for all the advice. I am really excited about taking control of my pool.
    I was in a hurry to get a test kit so I bought a Taylor K-2005 from a local Pool Supply and ordered the Taylor K-1515A FAS-DPD drop test online.
    For the last couple of nights I have been up late reading, testing/adjusting and retesting to get my pH down from 8.4 to 7.2 with the help of the pool calculator and muriatic acid. Tonight, or I should say this morning I added almost 2 gallons of 12.5% bleach to bring my FC up and start the SLAM process.
    38,406
    Do you have the FAS-DPD yet? Hard to SLAM properly without it.
    Jun 2013
    Fontana California
    56
    My FAS-DPD (Taylor K-1515-A) kit came in the mail today!
    My results were as follows at 9:30 pm
    FC 15
    CC 1
    Should I be doing any other tests while SLAMming the pool?
    I added 15 oz of bleach per the pool calculator to raise my FC up to 16 and brushed the entire pool. The water looked real cloudy after the brushing and it is too dark outside to tell if it is green or not.
    Should I retest later tonight or wait until the morning?
    38,406
    You should hand confirmed and adjusted the pH before starting to SLAM. Let the FC drop below 10ppm before you check the pH.
    Then continue to SLAM. Have you verified the CYA with your test kit? You should do that first.
    Jun 2013
    Fontana California
    56
    I started adjusting the pH Monday night down from my reading of 8.0+ per my test kit adding a little muriatic acid at a time until I got it down to 7.2 Thursday night. At that time I tested my FC and it was at 0 and my TC was 0 so I plugged the CYA number I got at Leslies into the pool calculator and added the required amount of bleach to start the SLAM process.
    Should I confirm the pH again and verify the CYA?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    We tend to find that CYA is the test most pool stores get the most wrong, for one thing the test is a bit harder to read than others, it takes a little time, and your need the right lighting conditions. It should be done outdoors in sunlight with the sun to your back and the view tube held at about waist level. You can pour the test solution back and forth for several minutes until you are confident in your reading. There are youtube videos that will show the correct process. This one shows the process for the TF-100 kit which uses the same chemicals, but a larger view tube http://www.youtube.com/watch?v=NxaqoW-_MCs
    Ike
    38,406
    Sounds like the pH might be fine, but definitely need to test the CYA yourself.
    Jun 2013
    Fontana California
    56
    I tested my CYA and if I am performing the test correctly my CYA appears to be below 30. I watched a couple youtube videos on the CYA test and I think you are supposed to add the solution into the comparator until the dot at the bottom is no longer visible???
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes, when the dot disappears take your reading.
    Jeff
    Jun 2013
    Fontana California
    56
    Update
    I don't think I have been testing as often as I should have but here is a summary of my results:
    Jan 10 12:00 am
    pH 7.2
    CYA 40 <~~~This is the only pool store test result listed. It does not appear to be accurate.
    FC 0
    CC 0
    added 240 oz of 12.5% bleach. Targeted FC 16
    Jan 10 8:00 pm
    FC 15
    CC 1
    Jan 11 11:30 pm
    FC 10
    CC 0.5
    CYA less than 30
    added 90 oz of 12.5% bleach
    added 15 oz liquid stabilizer ( I was reading the wrong value from the pool calculator
    which I did not realize until my last test on Jan 13)
    Jan 12 1:30 pm
    FC 14
    CC 0.5
    CYA less than 30
    Jan 12 9:00 pm
    FC 13
    CC 0.5
    added 45 oz 12.5% bleach
    Jan 13 1:00 am
    FC 18.5
    CC 0.5
    Jan 13 9:30 am
    FC 15.5
    CC 0.5
    added 15 oz 12.5% bleach
    Jan 13 11:00 pm
    FC 11.5
    CC 0.5
    CYA less than 30
    added 67 oz 12.5% bleach
    Jan 14 1:00 am
    FC 20
    CC 0.5
    added 78 oz liquid stabilizer
    Jan 14 7:15 am
    FC 19
    CC 0.5
    Am I getting close?
    38,406
    Well those last 2 tests appear to pass the OCLT, the CC are in range, and the water looks pretty clear (hard to tell).
    So you see any algae or cloudiness? I might suggest doing the OCLT one more time tonight since you still saw a loss of 1ppm in only 6 hours.
  20. Back To Top    #20
    Jun 2013
    Fontana California
    56
    I don't see any algae. I wasn't sure about cloudiness yesterday so I asked my wife and she said it looked just a little cloudy about the time I took that picture. The wind has been blowing hard since yesterday and I keep brushing to make sure the stabilizer isn't settling in the bottom of the pool so I see a lot of particles floating but I don't think it is cloudy.
    Jan 14 4:30 pm
    FC 14.5
    CC 0.5
    CYA 35-45 <~~~I'm not sure of this reading but at least it is finally above 30 ppm
    added 52 oz 12.5% bleach to get FC to 20 in case my CYA is 45 per the Chlorine/CYA chart.
    Is it possible to tell if my CC is below 0.5 if I am testing using the 10 ml sample where 1 drop = 0.5 ppm?
