Thread: Jacuzzi stopped pumping high. Both pumps working.
    I have a jacuzzi select series. Once in a while the spa would pump low but not high, with both pumps running.
    I had a issue with one of the starters on the first pump and took it in to have it repaired. Hooked everything back up and spa was fine.
    All of a sudden it stopped pumping high again, so I took the pump back out and ran to the pump repair store. They said nothing is wrong with the pump, it must be air in the system.
    I hooked the pump back up, refilled the spa and followed the air removal methods described in this forum - I bled water at the unions (both pumps), tried bleeding with the drain valve on pump one (pump 2 does not have one), and tried putting my hose at each jet.
    Any thoughts on what to do next?
    Notes:
    on one of the jets (a 3-pack), I notice water and air pumping up and down in the line when the system in on high. The line never looks complete filled with water. When I put my finger over one of the jet holes, it fills up, but as soon as I let go, the air bubble re-appears.
    both pumps are pumping. My low cycle is too low and the high cycle is like I am on low.
    I feel water being sucked in at the filter hole.
    The union at the second pump only looses water when the system is on low. As soon as I put the system on high, it no longer leaks, even when loose. Is that a clue?
    Karen from Arizona
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Jacuzzi stopped pumping high. Both pumps working.
    welcome to TFP! Sorry I can't help, but hopefully someone who can will stop by.
