Results 1 to 13 of 13
Thread: Auto-fill freeze protection?
    We are expecting coldest temps in over 10 years here in the ATL area over the next few days. Does anyone have advice on how to protect the auto-fill line from freezing and cracking? It is pvc under pavers, comes out and connects to a flexible cloth-covered hose that then connects to the spigot coming out of the house.
    Also, the pool pump comes on when temp drops below 35 but is there a need to protect any of the exposed pipes around the pump/heater?
    I'm a new pool owner, this is only our second winter with the pool, and last winter was VERY mild. Temp is expected to go down to 3 degrees Monday and stay in teens on Tuesday! Any advice is much appreciated!
    30,432
    Re: Auto-fill freeze protection?
    Welcome to the forum!
    Shut off the spigot and disconnect the auto fill.
    The flow of water through your pool plumbing is all you need.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Any pipes under the pavers and underground are probably buried pretty deep so they should be protected from freezing. But with those temperature extremes, I would drain the pad equipment for extra protection. You can also tarp the equipment and put an incandescent light bulb underneath the tarp.
    Mark
    Thanks..we are going to hope for the best with the pump running and also covering the equipment with a car cover and placing an incandescent light underneath for warmth, and we disconnected the auto-fill line from the spigot.
    Nov 2013
    Charlotte, NC
    4
    Quote Originally Posted by mas985
    Newbie in NC here - 1st winter and elected to keep pool open. Planning to tarp and light for the next few days as suggested ( have auto that kicks pump on at anything below 34 degrees). Is it still necessary to drain pad equipment? We're supposed to see single digits for a few days and below freezing for the week. Thks!!
    30,432
    No one can answer that general question but you. I live in Raleigh. based on what the forecast I see, I would plan on covering with a tarp and running the pump 24/7. Should you do more? Hard to say.
    If you drain your lines, any water above ground now will freeze.
    There is great protection when water is flowing through your pipes. Whether or not it is enough after you tarp it is a judgement call only you can make.
    Nov 2013
    Charlotte, NC
    4
    Thanks Dave
    My freeze protect will run anytime temp is under 34, so water should be moving the entire time. I didn't understand the "draining of the pad". If I understand correctly all items are flowing when the pump is running so why drain?
    30,432
    I believe that to be more applicable for much further North than we are. The temps there stay below freezing for much longer periods of time so running the pump 24/7 and counting on flow alone to protect your pipes is not practical.
    The cold we'll get is below freezing for a very short period of time so running the pump makes far more sense to me.
    Nov 2013
    Charlotte, NC
    4
    When the intermatic kicks on at 34, doesn't that run the pump , or am I missing something? In other words, things will be running 24/7 or close to it for the next week or so. Thks!
    mas985's Avatar
    Pleasanton, CA
    11,743
    There are several reasons to drain pad equipment over running the pump. First, a lot of things can and do go wrong including losing power and even freeze protection failing to work properly both of which have been reported multiple times on this forum. Draining the equipment is fairly easy to do when the pool water is lower than the equipment and alleviates the worry of those two things happening at exactly the wrong time. Also, running the pump may not protect all of the equipment. It depends on the layout and what freeze protection can operate.
    Mark
    I think Mark is right.. I am not sure freeze protection cutting on the pump sends water thru all the exposed pipes--
    like the ones leading into the heater.. but as a new pool owner I have no idea how to drain the equipment, never thought I'd have to. Temps coming to this area are lowest since 1983. We covered everything on the pad with a canvas car cover held down by bricks and have a 200 watt bulb...and praying
    mas985's Avatar
    Pleasanton, CA
    11,743
    It is pretty easy. For an IG pool with the equipment above ground, you should only need to remove the pump lid and maybe open the air vent in the filter. Gravity should do the rest. But you should be ok with the tarp and light bulb.
    Mark
    and pull the drain plugs from the pump strainer and impeller housing...
