Thread: Frozen R-0871
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    Frozen R-0871
    I had some Taylor R-0871 delivered via USPS. Of course the day I forget to check the mail it is delivered and the overnight temperature was 9 F.
    R-0871 is frozen solid. The R-0003 did not freeze.
    Can I just set the R-0871 on the counter to thaw out and use....or is it kaput???
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    30,432
    Re: Frozen R-0871
    If you are on municipal water, test your tap to see if you get an FC reading.
    I imagine you are OK. If you got it from TFTestkits, let us know and we'll take care of it if needed.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Frozen R-0871
    Some municipal water like mine, uses CC instead of FC.
    Mark
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Frozen R-0871
    You can still get a reaction, even if you have to use both reagents.
    Essential Links:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Frozen R-0871
    For what it is worth, I have had R-0871 freeze in the past, and it still compared reasonably to fresh R-0871...ymmv
