Results 1 to 7 of 7
Thread: Hayward Navigator opinions?
    The pool cleaner that came with my home purchase 8 months ago is on its last legs. It is an older model hayward that worked well until now. I have a small pool and a suction style is fine for our needs. Any thoughts on the Navigator? I've heard good and bad. Thanks!
    New pool owner 3/2013 14,000 gal pebble tec, 7 ft jacuzzi with spillover into pool.
    FNS +48 DE filter, raypak2100 heater, Pentair whisper flo 1.5, Hayward pool cleaner. TF 100 test kit.
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    Re: Hayward Navigator opinions?
    Quote Originally Posted by Jmerich
    In my experience, the Navigator and it's multitude of variations do one of the best jobs of cleaning a pool. The downside is that they are the worst for longevity. Plan on replacing parts every 12 to 18 months.
    I tend to drift towards the types that have one moving part - like the Barracuda and my favorite, the Pentair Kreepy Kruiser. The Kruiser is the only vac I know of that comes with a 2 year warranty.
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
    mas985's Avatar
    Pleasanton, CA
    11,737
    Hayward just purchased ThePoolCleaner so they must think it is a pretty good cleaner. IMHO, it is a better cleaner than the Navigator and it has lasted me over 8 years so far.
    Mark
    Jan 2014
    Corona, CA
    7
    I started with a Kreepy Krauler, cleaned well just always getting stuck in my pool. Replaced it with a Navigator about 7 years ago, works but like other say it is Pool Shops dream.... I have replaced almost everything other than the hoses and other shell at least 3 times, shoes and flaps are lucky to last a year. Parts really add up on this thing.
    When I told my pool shop owner I just bought the Poolcleaner, he looked upset and told me I would not be happy and that the parts are way more expensive than the Navigator..... I guessing is angered by seeing another customer get clean from a navigator replacement parts addiction.
    I based my purchase of the Poolcleaner on countless positive reviews.... So I am hopeful that is works as well as every says.
    Doug
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I have the Navigator Pro XL. I was initially not a fan, but going through my learning curve and lets say a unit Break-in period, I'm pleasantly surprised with the performance; I'll give it a 7 of 10. Using original internal parts/flaps since December 2012 with no issues since. I've found replacement parts on-line inexpensive. If you care to read, my saga is here http://www.troublefreepool.com/threa...roblems-Solved
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Also, to keep the trash from the pump-strainer, I recommend the in-line leaf strainer. http://www.bestbuypoolsupply.com/media/W560.jpg
    Jun 2011
    Long Beach, CA
    2,778
    I've had ThePoolCleaner for 3.5 years now and the only parts that I have replaced are the tires at the end of last summer.
