Results 1 to 7 of 7
Thread: Chlorine in Winter
    Fort Worth, TX
    83
    Chlorine in Winter
    I'm running my pool through the Winter.
    I've still been testing and keeping the proper balance.
    Is there any use in maintaining a chlorine level when the water is probably around 45 degrees?
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Chlorine in Winter
    Yes, I would maintain an FC level. You can bring your FC level up to SLAM level for your CYA level. With the colder water temp your FC level will hold a lot longer.
    Algae can start at water temps around 60. Plus or minus a few degrees.
    Jeff
    Re: Chlorine in Winter
    The chlorine continues to keep the water sanitary which is the main reason I maintain it during the winter. As noted, algae growth slows dramatically, and isn't as much of an issue. But chlorine consumption also drops dramatically, so it's easy to maintain.
    Note that there is no reason to bring FC up to SLAM level if you're keeping your pool open unless you prefer to do that versus maintaining normal levels.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    At any rate I would maintain FC levels. There would be no harm if done with either method. Choice is yours.
    Jeff
    Oct 2012
    Houston TX 77064
    101
    Just as a gage - in Houston, water temp 55-50 for the last few weeks (outside temp low 32-high 60), I have only been adding 1 cup of bleach every other day. Really slow consumption. FYI: PH/AK same, holds for weeks sometimes.
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by BillB
    Yes. It's easier to prevent algae than get rid of it. Instead of fussing around with a cup at a time, I raise FC a couple points above minimum and go a few days or a week between additions.
    All it takes is a good winter storm to blow all kinds of organic material in the pool and all your chlorine will get used up overnight.
    Oct 2012
    Houston TX 77064
    101
    oh, I apologize, forgot to say - CYA 50, FC 9, CC-0 - one cup every other/or two days keeps it right there.
