Results 1 to 10 of 10
Thread: Need install advise on new Intellipro
    Cypress, TX
    37
    I just ordered an Intellipro to upgrade my existing Sta-rite 2HP Max-E-Pro pump. I think I may be able to just reuse the existing wet end and just replace the pump portion. If not I have some questions. I know the new pump comes with unions. Hopefully the new pump has the inlet and the return in the exact same place. If it does I was thinking of cutting the gray pipe right above the threads. I assume the unions have a 2" female connector. Is that correct and does that look like it will work looking at the pictures below? I was also thinking of getting an extra set of the unions so I can use my existing pump as a backup provided the ports are exactly in the same place.
    I also have some questions about the EasyTouch 8 I have. It was installed back in 2007 and does show the Intelliflow pump in the menu. I hope this will work straight away as my understanding is my vintage EasyTouch cannot be upgraded. Anyone have any insight on this? Any help or tips here would be greatly appreciated.
    Thanks!
    Steve
    25,000 gallon saltwater in-ground pool with in-floor cleaners. Medium lagoon plaster. Jandy pump and heater and Glacier Pool chiller. Use iRobot Verro pool cleaner.
    Re: Need install advise on new Intellipro
    I had a Max-E-Pro and the fitting did not match my 011012 Intelliflo VF pump, had to re-plumb everything.
    What is the current firmware of your Easytouch 8?
    This change log would suggest VS pumps are working...
    Firmware change log; "Version 1.060 8/16/07
    IntelliFlo VS now uses HIGHEST RPM as priority of circuits which are ON rather than pump priority of 4 thru 1.
    IntelliFlo VS now honors 30 sec pump OFF for valve turns"
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Cypress, TX
    37
    Quote Originally Posted by jerryt
    I purchased the Intellipro pump not the Intelliflo. The Intellipro uses the Sta-rite design. I need to check the firmware version when I get home later. Thanks!
    Steve
    What was the question about Intelliflow showing in the menu?
    Cypress, TX
    37
    I was just wondering if there were any issues running an Intelliflo/Intellipro on the older EasyTouch Units. I am pretty sure mine is the older version that cannot be updated. I am hopeful it will work as it does show have a menu item for the Intelliflow where you can change the 4 speeds. I will get the exact version of firmware I have later when I get home from work. Thanks!
    Steve
    I assume your Intellipro is 2 speed? In that case it uses a 2 speed relay.
    Intelliflo pumps use a RS485 communication cable, to send commands to the pump. Pump is wired to "power always on", no relays...
    Cypress, TX
    37
    Jerry,
    The Intellipro and Intellipro are exactly the same and uses the RS485 cable as well. It is just the wet side that is different. The Intellipro I purchased is this one:
    http://www.pentairpool.com/products/pum ... mp-437.htm
    This is the updated version that has the 8 programmable speeds.
    Steve
    I would call Pentair and ask if that will work with the earlier Easytouch boards.
    Check your PM
    Cypress, TX
    37
    Looking at the version history I think the version I have will work. At least I hope. I am running 1.050. Below is the revision history:
    Easytouch Firmware Version History
    vers 1.010 Production release of 1.006 updated autosync for Intelliflo 4
    vers 1.020 Production Released, synced menu.c, menu.h, menusel.c, menusel.h w/wireless
    vers 1.043 Allow temp adjust when aux circuits are on
    Sync'd menusel,menu files with indoor & wireless
    Corrects "Heater" assignment under valves
    Adds new Intellichlor menu for separate pool/spa % when available
    Indoor/Wireless -- fixes pool turning off when a circuit gets turned off
    Indoor/Wireless -- fixes pool/spa switching by arrow keys
    vers 1.050 Fixed circuit selection issue with IS4,Qt4,Intelliflo, & 2 Speed on all models
    Fixed AM/PM/Day of the Week display bug on UIC/UWC
    vers 1.060 8/16/07 Release to Production
    vers 2.010 5/5/08 New Processor Upgrade, requires version 2.010 and higher. Can not be applied to older EasyTouch systems. Added Intellibrite support.
    Cypress, TX
    37
    I just spoke with Pentair and they said no problem with using the 1.x Easy Touch firmware with the new Intellipro pump. They said I will have access to the 4 Speeds tied to the circuits I choose but will not get status info without a newer Pentair automation system. Once I get the pump I will write up my install and configuration as I have seen a bunch of threads that showed confusion on how to physically wire it in and configure it. Thanks for the help everyone.
    Steve
