Thread: indoor Pool ( Wall & Cieling construction Methods )
    Dec 2013
    Vancouver, BC. Canada
    4
    Ihdoor pool (construction design methods) for walls/cielings.
    I've been unable to get a direct answer from contracters engineer!
    Regarding, (Wall Construction)
    matierials used in constructing walls. ( listed from inside wall to extierior of wall )
    1) moisture resistant mess tape & compound
    2) moisture resistant 1/2" drywall board
    3) 2"x6" Extierior walls 3 1/2" ( R -21) Polarfoam PF7300-Soya CCMC certified 2 lb. polyurethane
    4) 5/8" plywood standard grade
    5) tyvec wrap
    6) single layer of tar paper not sure om grade apeared to be a quality product
    7) stucco mesh & 1st application of stucco
    8) 2nd finishing coat was applied with an elastimeric type of additive for moisture block
    Lastly buildings HVAC system was approved & passed by engineer
    Q. Will this method of biuld prevent moisture migration inside the wall cavity thus, moisture damage &
    formation of molds?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: indoor Pool ( Wall & Cieling construction Methods )
    This is not a direct answer to your question, but I can tell you what has worked for me, with an indoor pool built a bit over 30 years ago.
    Concrete and metal building with blown in foam insulation with good exterior grade wood siding for panelling on most interior walls
    Here are some photos I posted of the roof replacement done last year
    my-not-indoor-pool-at-the-moment-t43536.html done last year
    Not shown is the kitchen, dining area, bathroom, bbq pit, etc. Wood siding you can see a bit of in one photo as well as the horizontal wood planks above the glass doors (making trough covering indirect lighting fixtures) is pecky cypress
    You may notice a warmer tone in the last photo, previously the interior concrete block wall sections (and old interior foam insulation) were painted off white with a blue tint, now they are off white with a sunset peach tint.
    Overall the pecky cypress has held up very well, only refinished once about 10 years ago, you may note one column behind the scaffolding torn out with old insulation showing, it along with other side and end corners were framed with conventional wood moulding and plywood which did not hold up so well in the long term.
    The bathroom has conventional drywall with cloth type wall paper which held up reasonably well, although the wall paper does need to be replaced every 10 years or so, much the same goes for the painted plater ceilings in the kitchen and dining areas.
    Ike
    p.s. here is a link to my solar heat installation thread with one outside shot with the new roof on, still needed some trim paint at the time the photo was taken though.
    solar-panel-replacement-update-t56572.html
    30,421
    Yikes! That's a bit above most everyone's pay grade. There's a lot of smart engineers on here but they are likely not pool engineers and in your area both.
    I would improve my line of communication with engineer or PB.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    I am no expert in construction, but I do know from other threads about indoor pools that ventilation is very important for controlling humidity. Ventilation with a powered HVAC system is good, but you should also have a passive ventilation system in place utilizing roof vents and windows or louvers.
    Love TFP? Become a
    TFP Supporter!
