Thread: My tests versus Pinch a Penny tests
    Hello all, I am a new Pool owner here in beautiful Clearwater, FL. I have a Taylor K-2006 test kit, and my total Alkalinity comes out to 70( number of drops times 10 to achieve color change). When I take the same water sample to Pinch a Penny, the number comes out to 110. Why is there such a difference? I see they are using the same reagents I am. Has anyone else had this issue? My PH climbs about .2 per day if I keep the "Water Decent" off. I let it bounce to around 7.8 and throw a Pint of acid in about every 4 days or so. I assume this is Normal for a new Pool.
    I have read the Getting started portion of this site. I am using the numbers that are posted here to maintain my SWG Pool.
    My Pool is 10,000 gal, SWG, Quartz interior(Plaster?) with a Hayward 3 speed variable set to run about 7 hours a day to turn over the water twice. the Pool is only 2 months old. about an inch or so evaporation a week. Chlorine is maintaining at 2.6 and Pool is screened in. Cyanuric acid is around 60+. Calcium is around 390.
    22,544
    Re: My tests versus Pinch a Penny tests
    Welcome to TFP.
    When you're doing the TA test are you dropping drops until the last one makes no change and then not counting that last drop? If not, try it and see what value you get.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    I'd say your situation is the norm. It's rare to have your test results match the pool store's. It's even rare to have the pool store agree with itself! inconsistency-in-readings-t61728.html
    Trust your own results. Study Pool School. Don't obsess over TA. It's the least critical parameter.
    thanks for the post. I count every drop I add. I am going to trust my test kit. Thanks for advice.
    Jun 2011
    Long Beach, CA
    2,781
    Just to reinforce what Bama said, you are not only looking for the color to change, but for the color to stop changing after adding more drops.
    My TA testing always gives me a slight change from green when the test is nearing the end. Another drop will turn the test pink and another drop will turn the test hot pink. Once the test turns hot pink, adding more drops will not change the color any more. This is the end of the test and in my case, I read the TA as the number of drops that it took to reach that hot pink color times 10.
