Thread: Bad hair (no oil)
    Bad hair (no oil)
    For some reason this year the pool is terrible on everyone's hair. It seems to strip all the oil and makes hair unmanageable w/o after-pool conditioner. This was not a problem the first 3 years of our pool.
    7.5 Ph
    2.0 Cl
    80 CYA
    100 Alk
    3000 salt
    The pool has a SWG and the only thing added regularly is HCL.
    CYA was recently added (was down to 40)
    Salt (99%, no anti-iron) was added early in the season
    Bleach was added (to 15ppm) a few months ago to shock after a bad DE Panel took out the SWG and allowed a small algea bloom (walls, not green water)
    I use some TriClor pucks in the winter.
    Other chemicals have never been used.
    The only thing different this year was the algae bloom and the Chlorox shock. Surely that's not causing it.
    Any ideas?
    Robert
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Re: Bad hair (no oil)
    Sorry, I don't have an ideas, but welcome to TFP!
    Someone, probably Waterbear, will be along shortly to help you with all your pool chemistry and hair care needs!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Guest
    Sounds like you might have hard water. What is your Calcium Hardness?
    200 but it's unchanged (pretty sure, but maybe I'll check)
    I've been lurking here for a while, but just haven't posted... since I had a question I figured it's better to post here rather than PF. (I did search both places)
