Results 1 to 15 of 15
Thread: Best place to buy bleach?
    I've read quite a few of your posts in these forums, and have taken in a lot of information. Based on that, I was wondering if anyone has tried any of this bleach online at amazon? I haven't begun the bleach adding yet, as I still have to order a test kit. Just looking for a little info on if I should pursue this brand, or stick with some other local stuff. Thanks in advance, and thanks for all the information I've read so far.
    http://www.amazon.com/Liquid-Bleach-gal ... rds=bleach
    @9,000 square feet
    IG Plaster pool approx 2-3 years old
    Pentair-011018-IntelliFlo-3HP-Variable-Speed-Ultra-Energy-Efficient-Pool-Pump 011018
    Pentair-Sta-Rite-S7M400-SM-Series-Cartridge
    38,267
    Re: Best place to buy bleach?
    Welcome to TFP!
    What is the strength? How old is the stock? Looks to be no better priced as you may find locally.
    There are calculators in the forum to determine the best deals.
    Dec 2012
    Manassas Park, VA
    206
    From the picture provided on Amazon it looks like that is 5.25% bleach which is not very strong. However 6 gallons for $11 is very good. I get my bleach from Costco 3 gallons at 8.25% for about $10.
    I also get it from Walmart when I need it quickly at about $3.50 a gallon 8.25%.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The pure brite brand bleach is good, I often get it through the family Janitorial and Cleaning supply company at cost, I can't comment on how fresh it is from Amazon though. My only complaint about it is the pull tabs on the lids often tear off without pulling the seal loose.
    Ike
    Quote Originally Posted by Rocco
    $6 shipping so it's more obv, but I pride myself on being a good shopper, or at least exhausting all avenues.
    @9,000 square feet
    Oct 2012
    Houston TX 77064
    101
    pool store - $ vs % always cheaper in NW Houston
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I think the Amazon listing is misleading. I believe it's $11.95 for each gallon. There's lots of conflicting information given. The physical size is 12.9 x 12.9 x 12.6 which would be a single bottle, but the product weight is stated as 59.6 lbs (or 58 lbs shipping?) which sounds like the case weight. There's no way a case weighing almost sixty pounds is going to ship for $6. A single gallon I can believe, but not a case of 6. Buyer beware!
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,082
    I'd stick with local stuff. $18ish for 6gallons of questionable quality isn't a huge deal. WalMart carries a gallon jug for just around $3 every day.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    + 1 to that ^^^^^^ !!
    Jeff
    Dec 2013
    Temecula - Southern California
    26
    $18ish for 6 gallons of 5.25% is $0.446 per oz of chlorine. That's expensive. I am getting $0.266 at my local pool store.
    20k gal, IG gunnite plaster + spa, 2 HP Whisperflo pump, Pentair 520 sq ft catridge filter
    Pentair Min Max NT heater. Intelli-touch i5 controller, Ultrapure ozone (currently disabled), Rainbow 320 chlorinator
    Small water feature, Water slide. Poolvergnuegen 2WD suction cleaner.
    New Brunswick Canada
    819
    my local pool store, sells 1 gallon 10% for 9.99 way more then local hardwarr store of 5.99
    Oct 2012
    Houston TX 77064
    101
    In Houston TX, I buy Pool Store Bleach at 3.99 per gallon for a 12.50% which is $0.24984 per oz (guaranteed potency), $.03 cheaper than Walmart's 8.25% at 2.99.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Have you ever tested that guarantee ? ^^^^^
    Jeff
    Oct 2012
    Houston TX 77064
    101
    Have not personally had to challenge, due to using the Pool Calculator and all the numbers reflect what it should. My local Pool Store (Warehouse Pool Supply) told me if the potency is off, please bring it back for exchange - they guarantee rotation of product, hence it's potency as well.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That's great. Good turn over is key. Glad you found a good source.
    Jeff
