Results 1 to 12 of 12
Thread: Topping up a SWG pool
    Does anybody have any tips on topping up a SWG pool for water lost due to evaporation?
    Mine loses a truckload of water every week!
    Is there a proper way to do it or do you just shove the hose in the pool and turn it on?
    Do you need to run the chlorinator and pump for any period after adding the new water?
    Thanks for your help folks!
    Michael
    60,000 litre pool (15,850 gallons)
    Cartridge filter, SWG pool.
    In ground pool, tiled concrete
    Viron P320 eVo pool pump, 300 litres/ minute
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Are you serious, a truck load a week ? That's not evaporation, that would be a leak. If your losing a truck load a week how have you been replacing it ?
    Yes you can put the hose right in the pool. I would think your salt levels would be off also.
    Yes you can run the pump after filling back up.
    Jeff
    Re: Topping up a SWG pool
    Sorry Jeff. Not actually a truckload. That's the Australian tendency for exaggeration coming through!
    I lose about a tile height in evaporation a week.
    The only reason I asked the question was because it occurred to me that I am adding fresh water that hasn't been treated yet to the pool, so I wasn't sure whether it was ok to just put the hose straight in the water, or whether you should add the new water via the skimmer box or something like that.
    I noticed at a friend's house that he was adding water while the kids swam in the pool. I thought that might be unsafe but maybe it isn't.
    Michael
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No problem Mick. I enjoy joking around as much as anybody. I was just like wow, that's a lot of water.
    Anyways, yes you can just put the hose in and let her go. Just make sure your salt levels stay ok and running pump like normal and you should be good.
    Jeff
    Thanks Jeff.
    I'll get it checked for leaks just to make sure. It's only 4 months old but you never know.
    Michael
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I think how you discribed it now it's probably evaporation.
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If by a "tile height" a week you mean 6 inches, that sounds like it could be a little much. If you don't know for sure, you might watch it closely and see what it really is.
    Essential Links:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    You can always run a bucket test to check how much is lost to evaporation. Partially fill a bucket with pool water, mark the inside waterline, place it on the pool steps, then mark the outside waterline. Let the bucket sit undisturbed for at least 24 hours. After 24 hours mark the new water levels inside and outside the bucket. If the water loss outside the bucket is greater than inside the bucket that could indicate a leak in the pool.
    Love TFP? Become a
    TFP Supporter!
    Think you. What a great idea!
    Michael
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Here's a link to look at pool-school/leak_detection.
    Jeff
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If it's not a leak as the water evaporates your measured salt level will actually go up (ppm due to being less water overall). Salt doesn't evaporate, but does lower due to splash out, and back washing.
    The bucket test will reveal.
    In the winter in Florida, it's our dry time and I'm adding water a couple times a month about 2-3 inches. (about 900 gallons)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good point bobo ! I think that was one of those very early morning Aussie questions and the brain wasn't fully functioning yet !!
    Thanks for the back up !!
    Jeff
