Thread: pump size question
    Mar 2012
    spain
    48
    pump size question
    hi
    I believe optimal size is 550w for my pool
    pump is broke
    I do have however a 750w laying around
    if I put him on 2hours on 750w instead of 3hours on 550w
    it will be the same and make no difference right?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: pump size question
    Are those EU specs or model #s. What brand is the pump?
    Having your location and some more details might be helpful. Please follow these instructions: pool-school/read_before_you_post
    Mark
    Mar 2012
    spain
    48
    hi
    i am in spain
    and I meant watts
    make is berlan 550watt 12.000 L/H vs berlan 750watt 16.200 L/H
    mas985's Avatar
    Pleasanton, CA
    11,741
    The bigger pump will just cost more to run. But run time has little to do with the size of pump. The pool can probably get away with the same run time either way but you can experiment to find out.
    Mark
    Mar 2012
    spain
    48
    but since the bigger pump filters more liters in 1 hour
    it could run less time or not?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Flow rates and turnovers really don't matter much for pump run time. Yes, to filter the same water you can run the larger pump less but that is not the main reason to run the pump. Pump run time is more about vacuuming and skimming than it is about filtering water. You might want to read through this: pool-school/pump_run_time
    Mark
