Thread: Air bubbles?????
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Air bubbles?????
    Ok, I am having air bubbles come from one return nozzle and out of the spa spillover ONLY when I have the vacuum hooked up to the skimmer. Any other time there is no bubbles anywhere.
    Is this something to worry about or could it be air getting by the spa valve that provides the spa with bubbles when in spa mode? Thanks
    Thanks Todd.
    15,000 gal. In ground, sand textured with beach area, spa located in beach area with spillover equal to pool level.Rock waterfall with 4 foot drop.Hayward goldline aquaplus automation all wireless remote.T 15 cell,Propane heater,Super 2 for pool/spa,Super 2 for waterfall.Cartridge filter and solar panels.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,048
    Re: Air bubbles?????
    Your vacuum hose probably has a pinhole in it. If your filter has an air bleed, vent the air out when you're done vacuuming.
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    No leaks in hose, it's a more amount of bubbles than a pin hole or small hole would produce. But there is no air in the pump or filter when it is doing it.
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Are you positive there are no air bubbles in the pump basket? It is very unlikely to have air coming out of the returns if it is not entering on the suction side of the pump. They may just be very small and not noticeable. Just to make sure, try some pool lube on the pump lid gasket and drain plugs.
    Mark
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    I will double check for air in the pump basket. Is it possible for it to be getting the air from the spa air supply?
    Thanks Todd.
    mas985's Avatar
    Pleasanton, CA
    11,741
    If air is coming out of a pool return, then it wouldn't be coming from the spa. The spa air vent will only draw in air when the jets are turned on but then they will only supply air to the spa jets and nothing else.
    Mark
