Results 1 to 12 of 12
Thread: New Liner - Pool Full of Mud
    Contractor installed a new vinyl liner. He neglected to pump the groundwater down. He said "the groundwater was coming in too fast for my pump". He installed a new liner with groundwater in the pool. My pool water is chocolate brown. My pool is full of mud with silty dirt all over the bottom. The filter system obviously is not going to get the dirt off the bottom. It would take months just to filter the water. What should he be doing to fix this? No, I haven't paid him yet.
    30,432
    Re: New Liner - Pool Full of Mud
    Has he told you he has a plan? Does it make sense?
    Oct 2012
    209
    I don't know that it would be groundwater for sure that made the water dirty. If we were to install the liner (even though we would pump the groundwater out first)....and there was still ground water coming in, the liner would be on top of it, with the exception of the cutting of the main drain hole. What was used to fill your pool? Municipal water, water trucked in, or well water?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    City water. The same that we drink. As he was installing the liner, muddy water was coming up through the main drain on the bottom of the pool. His plan thus far is to run the pool filter and put a bag of shock treatment.
    Quote Originally Posted by jimpimentel
    If muddy water is coming from the main drain as you say.
    Either the liner is not sealed around the drain or even worse your drain could be cracked.
    Where do you live? How long was your pool drained down for the liner replacement?
    Did you have a heavy freeze?
    Near Jacksonville Florida. No heavy freeze (it has been 50's and 60's). Pool was not even drained all the way down as best as I can tell. He did not pump very long. Was trying to get it done before Christmas. He did next door neighbor's pool a few years ago, no problems. He even remarked he knew (before he started) the groundwater was very high because of his experience next door, as opposed to another house in the neighborhood about 1/2 mile away which was dry. He pumped for maybe one day, with the end of the hose maybe 20 feet from the deep end dumping into my yard. Last time it was done, 12 years ago the guy had to pump for a week with two pumps, and set the end of the hose near the street. This guy put in a new drain cover. Obviously, with a pool full of muddy water (can't see even past a few inches) I have no idea what is going on in the pool, although I can see brown dirt on the bottom of my highest step. I ran my Tigershark filter unit through the pool, came up with brown mud. I backwash the filter, it puts out chocolate brown water. Should this guy drain the pool, clean the liner, and start again??
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It sounds like too much to ask of your pool filter system. If it were me, I'd talk to him and see if we could work out a better plan.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes I would for sure have a sit down with him and see what he's going to do about this. I don't see how this is your problem.
    Jeff
    Thanks everyone for your comments. We'll see how it goes tomorrow.
    Oct 2012
    209
    Is your pool holding water....any drop in the water level? Can you post pics? If there was enough dirty groundwater coming in to make the whole pool dirty, It would be nearly impossible to get a decent seal on that main drain.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Keep us posted, I'm interested in the outcome and wishing the best for you.
    Essential Links:
    May 2013
    Albany, NY
    59
    Any updates on a plan to resolve this?
    Eric Adams, Technical Specialist, Radiant Pools
