Thread: Installing Solar Heater on Roof
    I am thinking of installing a rather large, 20'X20' solar pool heating panel on my flat roof. I calculate the load to be about 4.3 pounds per square foot. Do you think the added weight will be a problem?
    30,413
    Re: Installing Solar Heater on Roof
    Welcome to the forum. I think we have to start by finding out how strong your roof is. What type of construction? Wooden rafters? How far apart? What size are they? What is the span? What is the sheathing on the roof?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What he said, also 20x20 is an odd size for a solar panel, what sort are you considering, and it would probably be helpful if you share your location and pool information if we are to give any other beneficial advice.
    Ike
    p.s. Also that is a LOT of weight, the panels I have only have a wet weight density of 1.31 psi (or 64 pounds per 4x12 panel) These are Techno Solis brand panels which weigh considerably more than most brands do, for comparison some Aqua Therm 4x12's panels have a wet weight of only 48 pounds or 1.0 psi wet weight density.
