Thread: Intex 15x48 uneven water level/lean
    I recently got a 15x48 intex frame pool
    we have fairly limited space in our backyard and the ground isnt quite event. I put it on the most level place i could however one half leans a little
    I've filled it about halfway and did a measure and at the moment there looks to be about a 3inch difference from one side to the other, steadily lowering and rising as it goes around the pool. I cant see anything on the frames or fabric to suggest stress though
    As I said the pool is about halfway full, should I expect the difference to grow as the pool gets fuller? I've stopped filling for the night and will reasses in the morning
    I've done some reading around and read that generall 1-2 inches is fine, just wondering if i can get away with 3inch for a month or so as we are in our hottest summer period, I can then umpty and level the ground for next summer. My main concern is the pool collapsing and dumping water everywhere as I said our backyard is quite small
    so to summarize, pool is half full with a difference in water level of 3 inches from one half to the other. Can the frame handle this for a month or so before I take it down for winter and work on levelling the ground?
    Thanks all
    22,542
    Re: Intex 15x48 uneven water level/lean
    Welcome to TFP.
    1" is fine, 2" is really pushing it and I wouldn't even consider leaving it 3" out of level. I know that it's not what you wanted to hear, but you really should drain it and relevel the ground.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Yep 3 inches is wayyy too much out of level. Get the spot where you want it level. If it's only 3 inches out of level it won't be hard to do. You do not want it to fail with people or kids in it.
    Jeff
    Casey's Avatar
    SW PA
    10,423
    Another vote to start over. As mentioned previously, 1" is fine. 2" is pushing it! 3" and disaster could strike and you're only half way full.
    STOP!!! DRAIN!!! LEVEL!!!
    Thanks for the help all
    Have stopped and will drain today, I've done some measurements so hopefully I can get it square next time
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you any problems post back. Good luck !
    Jeff
