Thread: Intellichem comport board connection
    I am hoping that someone on the forum with an Intellichem might be kind enough to pop it open and check out the answer to this question. I would call Pentair but they are closed for Christmas...
    OK - last week I installed an Intellichem. In the course of installation, the small circuit board that has the J7 com port block for the comm wires on it became unplugged from the ribbon cable that attaches it to the main board. My problem now is that the six-pin connector on the end of the ribbon cable will fit either way up, and after searching Google for hours I have still not found the answer as to which way to orient it.
    The small circuit board attaches to the main circuit board with a ribbon cable that has a red stripe on one side (I guess for pin 1??). On mine, this ribbon cable is plugged into the main board with the red stripe on the left and the cable dropping down, which I assume is correct. Now, on the small board, with the board oriented so that the writing on the board is the right way up and the FOUR terminal com port is at the bottom, should the ribbon cable be plugged in with the red stripe on the left and the cable going down or with the red stripe on the right and the cable going up?
    I would love to get this finished if any Intellichem owner can find the time to drop the front and take a look...
    A Merry Christmas to all.
    21,500-gallon tiled gunite with 65' infinity edge. Two Intelliflo VS pumps, one for trough one on pool. Pentair 520 cartridge filter on main circuit ,Pentair 200 cartridge filter on edge circuit. Easytouch, Intellichlor 60, Intellichem with external acid pump, Intellibrite 5g lights.
    Testing: Taylor K2006 (with FAS/DPD). Taylor K1766 salt.
    Re: Intellichem comport board connection
    Second page of the firmware upgrade instruction has this picture.
    http://www.pentairpool.com/pdfs/521499B.pdf
    Red stripe on left at the top ISP programming port and red stripe on the right side at the "Communication interface daughter board".
    I had the same problem when I received my intellichem.
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Thank you so much - I really appreciate your help. Seeing as we both had the same problem, maybe this post will be useful to others in the future...
    Mar 2013
    maryland
    138
    Follow up to this question for future readers. The board pictured above is an older intellichem board. The newer board currently "Revision B" does not use the extra daughter on the bottom and the comm wiring goes directly to the board at the same connector. In the revision B board the gray ribbon cable is only to upgrade firmware.
    Interestingly, my revision B board died recently and I had to use my old board which had been damaged in a lightning strike. The old board works when I hook it up directly to the com wiring like the newer revision B without the extra daughter board. I supect the daughter board was fried, but the Intellichm board saved. If someone sees this I would love to know why it works without the comm board. Thanks.
    " A little knowledge is a dangerous thing"
    19,000 gallon sylvan pool, Easytouch 2 4p automation, Screenlogic interface, Intelliflo VF 3050 pump, Intellichem with Intellichlor 40 chlorinator/Muriatic acid, Raypac millivolt natural gas heater.Polaris pool cleaner with booster pump.Coverstar automatic cover hydraulic mechanism with PCS cover. Wet edge Luna quartz finish 2016. Northeast climate.
