Thread: Pentair EasyTouch Aux Functions Not Working
    May 2012
    Brevard Co., FL
    29
    I have a Pentair EasyTouch 4 System with AUX1 set to LIGHTS and AUX2 Set to JETS. AUX3 is not used. I have Fiberstar Treo LAU-FS2 Color Lamps. The system has worked fine for a year but now the AUX1 and AUX2 buttons on the remote do not turn on the lights or the jets. The diagnostic test on the remote passes all functions including the AUX buttons. Both the lights and jets circuit functions are set to GENERIC. And the lights can be turned on and off from the master panel in service mode. I have not tried the jets from the panel yet.
    Any suggestions on other settings or what to try next?
    12000 GAL Total Pool & Spa-1000 GAL Spa/IG/Exposed aggregate/Cartridge CC200/Pentair VS-3050 (174 GPM max.)/SWG-Pentair Intellichlor IC-40/Pentair EasyTouch4/ "The Pool Cleaner"/Screened Enclosure/ Taylor K-2006C Test Kit.
    22,553
    Re: Pentair EasyTouch Aux Functions Not Working
    Try the jets and if they work from the panel, it's probably something in the programming.
    May 2012
    Brevard Co., FL
    29
    Went outside when it was daylight and tried everything from the panel. Pump, Pool/Spa valves, jets, lights, etc. Everything worked. So I ended up just pressing the RESET button on the panel. Now everything works again from the remote.
    22,553
    Glad it was that easy!
