Thread: Need opinions on this wooden pool deck.
    Matt Ush's Avatar
    May 2012
    46
    We are renovating a residential pool which has been built into a wood deck. So imagine a deck (40x40) with a small octagon pool dropped in. The land beneath is on a hill so the pool is half in ground, half above ground. The track for the liner sits on top of the deck and bolts to the deck. The coping (pavers) sit right on top of the deck and end abruptly making the pavers sit 2 3/8 inches higher than the wood deck. This looks not only dangerous but makes for quite the eye sore.
    I would like to rip this out and have the coping sit level/flush with the pool deck which is where I need everyones help. I can remove all the deck boards and replace the 2x8s with 2x10s. This will raise the deck boards 2 inches making them level with the pool. In my opinion this will be the most complicated solution. This also requires replacing all the boards. My goal was to refurbish the existing boards with a pressure wash.
    I would like to hear suggestions/see pictures of examples which will require the least amount of modifying.
    Option 2 is to rip the pool out entirely as the residence sits beside a lake. At this point, ripping the pool out will be a lot cheaper for us than bringing it back up to par. All the filtration equipment is shot as well as the liner.
    Inground Concrete Pool With Fiberglass Walls (20,000 Gallons), Hayward .75 Super Pump, Hayward S200 Sand Filter, Pentair IntelliChlor IC40
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Need opinions on this wooden pool deck.
    I'm one of those don't fix it if it ain't broke kinda guys and I actually like it. Question is, are those pavers just sitting/glued on top of a resin or steel top rail?
    SW Georgia
    300
    If it were mine and I knew I was going to have to replace the liner and filtration system (assuming I wanted to keep the pool) I would try a less expensive possibly temporary fix to the wood deck. You could get a 4 x 6 and create a threshold that transitioned from the wood deck to the pavers or you could come out say 4 ft from the pool edge and create a sub-deck that was 2-3/8 inches higher than the rest of the deck putting the height difference in the decks away from the pool edge. The best thing about the threshold idea is if you don't like it down the road you have not sunk that much money into it.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
