Thread: Help with choosing new pump/filter for next season
    We got through last year using the equipment the homes previous owners left. A 2hp 1 speed doughboy pump and sand filter. I know for our approximately 18k gallon pool the pump is way oversized. I was looking at the pentair matrix 3/4 HP 2 speed pump. I'm hoping for an 8 hour turnover.
    The pool is a 28' ag with deep center, a center main drain, return and skimmer within 5 feet of the equipment pad. I'm having trouble finding the curve chart for that pump on low speed and understanding the math to pick out a good sand filter.
    18000 gal partially buried doughboy ag
    225 lbs. Sand Filter
    Single stage powerpak II pump
    30,421
    Re: Help with choosing new pump/filter for next season
    Most all sand filters have a gpm rating that is pretty helpful. If you have found the curve for the proposed pump on high, simply take that gpm the pump will give you and add about 25% to that for the gpm of your sand filter.
    It doesn't have to be exactly 25% but close to that number will be fine with bigger being a bit better.
    OK so then the sand dollar 60 would be close and the 80 would be better
