Thread: Pool deck coverings
    Pool deck coverings
    I have a situation here that I could use some advice on. My indoor pool is aprox. 5 years old and for the last 3 I have had issues with the pool deck covering bubbling and ultimately cracking leaving bare spots on my deck which are unsightly to say the least. The company who did the covering tells me that the original concrete was of an improper mixture causing their product to not adhere properly. Their solution is to strip their product, shave at least 1/4" of the top layer of concrete, reapply a proper mixture of concrete then reapply their product. On one hand that sounds reasonable but the spots they repaired 6 months ago are having the same problem. Therefore I'm hesitant to go through with their plan. No assurance that it will be at the very least a long term solution. I am trying to contact a couple of competitors but this company has the market pretty much cornered around here. I would even entertain the thoughts of alternate coverings. Anyone have any opinions? Thanks.
    21.7K Gal AGP, Oceanic 28'x54", 1HP/2Spd Optiflow w/150sq ft Black Diamond filter. Installed 05/2013, BBB and TFP Reluctant Rookie!(ask my wife, she'll explain!)
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Re: Pool deck coverings
    Can you name the product or company you used? I've been considering something like Sundek coating on my pool deck and the cement on a screened in porch just to make it more attractive.
