Thread: Intex untra frame frozen...oops!
    Yes, I'm a newbie,...and I screwed up I think. I have a 12'x24' untra frame intex. I bought one of those winterize kits and a 12' long pillow to use with the original cover . I'm in north Missouri btw. I thought I did it right,... I filled it halfway, mixed in the packets in the kit with the pump for a few hours,...put the pillow in , covered. Ist problem,...the cover that intex gives you is sooooo cheap. A little wind ripped gromets on one side,...ruined it. Intex doesn't even have replacements in stock. Now...uncovered,... I have about 1 foot of ice on top. What do I do now? I don't leave it do I ? I can't break it, it's pretty thick. I wondered about using the pool antifreeze before, mixing it with the pump...but some places said it's for the pump and lines ONLY. I was smart enough to take the pump assembly and hoses inside. Any ideas?....THANKS BTW
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Don't worry about the ice. Some pools freeze almost solid.
    No need for the pool antifreeze either.
    Jeff
    Casey's Avatar
    SW PA
    10,448
    Re: Intex untra frame frozen...oops!
    Leave it be. There's nothing you can do anyway.
    My husband has concern over ours. This is his first pool. I told him it's fine. I don't mess with it until I'm ready to pull the cover off.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    You're fine! We left our intex up and it froze. No problem at all. I'd get a regular pool cover and throw it over top to keep stuff from getting in between now and spring but no worries on the freeze!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    Jun 2012
    western NY
    1,560
    Don't worry about it. Here is my block of ice...er...pool.
    2 days after I took this picture it hit -15f. No problems. The big hump in the middle is a plastic 55 gal drum from the hardware store. Cost me $10.00 12 years ago. Best cover float I have ever used.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
