Thread: Suntouch water sensor Not displaying Celsius correctly
    Sticky's Avatar
    Oct 2009
    WoyWoy Australia
    90
    Hi
    SunTouch controller ;
    I just put a new sensor for water , being in Australia I want it to display Celsius but as with the previous sensor from when that was new when I change it over it shows the pool temp as 255C when I set it to show Celsius , I can only adjust it down to 175C , I did cut the pool temp wire down to about 8ft would this change the resistance ? .
    I don't have a multimeter about time I guess to get one .
    Left as Fahrenheit the values show correctly .
    I guess it more annoying than crippling .... but why would F temps show ok but not C temps .
    Also the old sensor had split vertically down the bulb what would cause this ? . The Solar system had been out of use for 18mths because of the delay in getting a new roof .
    Thanks
    dave
    Ok update i just went out to see something now when i put it into Celsius mode I get ERROR on both the solar and water sensors , I have to go right but to the start of the menus go to Advance the reset to Fahrenheit and the temps are normal again . grrrrrrr
    7 meter by 2 Meter pebblecrete , VF intelliflo , Pentair ECO-CHLOR 25 , 5 helicol Sunx 40 solar panels & a Associated controls solar controller with an intellicom 3 to control the VF and relay to switch to valves .
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Suntouch water sensor Not displaying Celsius correctly
    Sounds like a controller problem of some type, the sensor should read the same for either F or C (if it reads right or not is another issue)
    Sticky's Avatar
    Oct 2009
    WoyWoy Australia
    90
    So there is aproblem with the SunTouch ? ...... would reinstalling the firmware or an upgrade solve it ? . I dont like doing firmware unless its Really needed .
    its always been like this from new and it worked fine in Fahrenheit mode from what I remember .
    I get the new panels on tomorrow so by the end of the week I will know if the ST controller is a bit flaky .
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sounds like you are not the only one with this issue, see this I turned up with a quick google search, http://ths.gardenweb.com/forums/load/po ... 15312.html , unfortunately there was no solution posted, but it does seem to be associated with switching from F to C.
    Ike
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You may just have another defective sensor. Try taking the good sensor and plug it in to the water slot on the board to see if it is a sensor problem, or a controller problem.
    Factory Warranty Station for:
    Sticky's Avatar
    Oct 2009
    WoyWoy Australia
    90
    Hi PC
    Ok I will try the solar sensor , but today when I switch to Celsius it just gave me ERROR on water and Solar this means sensor are not connected and when I changed it back to F it still showed ERR . I had to back out of the menu and start again .
    Fahrenheit works ok if I leave it alone .
    I think it may be the motherboard .
