Thread: White Powdery Substance
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    I had my pool closed on 10/31 and today I opened the cover just to see what's going on in there and I noticed a white powdery substance on the bottom of the hot tub and some in the pool as well. The water is very cold as we're having a really cold winter so far (although it was 60F today and its gonna be 70F tomorrow). Is it possible that one of the chemicals has precipitated out since the water is so cold, is it something I have to worry about? I'll get pictures posted tomorrow.
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: White Powdery Substance
    I'd suspect it's DE. Maybe someone didn't do a perfect job draining the filter to winterize it somehow.
