Results 1 to 8 of 8
Thread: Baquacil Conversions?
    New Jersey
    51
    I noticed there is no Baquacil Section, or at least a Converting from Baquacil Section.
    I should think there is a need for one, with the number of conversions we saw on PF
    30,432
    100% agreed.
    The"goo" victims will soon show up here in larger numbers...they need a forum of their own to get the special advice required.
    I'll volunteer to write the 'sticky' on converting, probably not until Monday, tho...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Knippa, Texas
    289
    Are you going to explain the bleach method, or the sodium percarbonate method?
    The bleach method can cause some serious CC issues in indoor pools, not to mention taking WEEKS. Ask me how I know. . .
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    OK - how do you know
    SW Connecticut
    18,000 Gal Freeform
    Gunite/White plaster
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    100% agreed.
    I can't believe your advocating ADDING a new area to the site! You're always Mr. 'less is more.'
    I'll see where I can stick it or maybe make another sub-forum.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    SeanB's Avatar
    Mar 2007
    2,622
    OK, it's there. Use it or lose it.
    TFP Founder
    Mar 2007
    Knippa, Texas
    289
    Quote Originally Posted by JSHILLING
    Just saw your post!!
    How do I know about baq conversions and cc's in indoor pools. . . I did a conversion earlier this year on my indoor pool. My CC's were up to TEN or so at one point. I tested and added chlorine at least twice a day, up to 5 times a day on weekends. It was weeks before the first step was visible, another week or more before the bottom of the pool was visible. CC's went down to 6.5, then around 4, then stuck there. Got new filter sand. 5 lbs of sodium percarb brought my cc's down to about .8. Went back up to 1.4 when I chlorinated again. Used hydrogen peroxide shock and lowered cc's to about 0.6.
    Now, months later, backwashing and refreshing the water, using occasional sodium percarb shock, my cc's are about 0.3.
    Sound like fun?
    ~Jules
    ~Jules~
    Taylor K-2006 test
