Results 1 to 11 of 11
Thread: Vacation procedure
    Vacation procedure
    Unless I missed it, I haven't seen a thread devoted to what all of you do prior to heading out of town for an extended stay. Instead of 'winterization", call this a "vacationization" thread. Since we all live in different climates, I don't know if we'll get a definitive "here's what to do to your pool before you leave town" check list. I'm mostly looking for an exchange of ideas so that we can all come home from vacation to a pool that hasn't turned into a pond! That being said, when you're going to be gone for, say, a week...
    1) do you leave your solar cover on?
    2) do you run the pump 24/7 or have a timed interval?
    3) do you top off with water? If so, how much?
    4) what's your chlorine procedure? (bulk up with bleach, load the skimmer with pucks, cross your fingers and pray)
    5) heater setting? (crank it down? shut it off? gripe about it after the utility bill comes?)
    5) do you have a neighbor "pool sit" or leave it unattended
    6) any other tips you can share from past experience (good or bad)
    Thanks in advance. While you're replying, I'm off to pack my sandals and black socks!
    Bill
    23K IG vinyl, Autopilot SWG, 1 HP Aqua-Flo Dominator Pump, 30" Cooper Ranger series sand filter, 1 skimmer, 3 jets, 2 fountains, 2 main drains.
    Re: Vacation procedure
    By far the best solution is to get someone you trust to come over and check on the pool. There are things that can happen that require human intervention, particularly a large storm.
    Failing that, solar cover, a trichlor floater, and the usual pump run time will normally be good for a week and likely two weeks.
    We have been good for a week with a SWG and little special preparation on several occasions. But once there was a large storm that blocked the skimmers , the pump prime protection shut down the pump and we got algae.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Yes, I do have some experience with leaving a pool for an extended period of time.
    Our vacation was a six week cross country camping trip. We live pretty far out in the country and there's nobody we would ask to come poolsit. I shocked it the night before we left to 20 ppm FC, turned off the pump, and we drove away. I had previously agonized about this on the forum, primarily because of my concern of an electrical problem with the pump and a possible house fire. I got some excellent advice which I'll pass on to you now:
    You know how to deal with a green pool. Go have a good time.
    Yes, the pool was green when we returned. We had expected that. It was clear and sparkling fewer than 10 days later using just bleach, brushing, and running the pump 24/7.
    I would do it again in a heart beat because I never once gave a second thought to that pool and just enjoyed our travels through this great country.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Sep 2007
    Lafayette, Louisiana
    344
    I'll be experimenting with this situation on a permanent basis when I get up and running. I work offshore oil and am regularly gone for one to 4 weeks at a time. I do have a couple very good friends that are semi-retired and volunteering to be my pool service while I'm away...for use of the pool of course...It actually works out very well for both of us.
    I opted to spend a little extra on my equipment to automate and take up the slack. I'm using an Intelliflo VF pump that should be able to keep the water turnover consistant, the largest residential cartridge filter I could get, AutoPilot Total Control to keep the pH in check and hopefully the chlorine, and a Polaris 280 robot to do some of the basic wall/floor cleaning. I'm hoping this allows my free pool service friends just to keep track of things every couple days while I'm away and make some small adjustments as needed. They can reach me via e-mail any day just in case something serious goes wrong...I've actually encouraged them to start reading the Pool School section here to get up to speed on some of the finer points of water chemistry.
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    Re: testing the water
    when testing your chlorine how long do you wait before you read the results? When I read it immediately after, i get a low reading. If I wait a few minutes (maybe 5), it's much higher. The longer I wait the darker the tube gets!!
    Cement pool 50,000 gals. nine foot deep at one end
    kidney shaped. Large DE filter and pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by JFP
    30 minutes to an hour.
    11,969
    I just returned from a 9 day trip. I was confident with my vacationization procedure only because I'm comfortable with my water chemistry and routine. I was away 11 days last year and had a friend check on the pool on day 4 and 8 and add 1/2 jug chlorine. This year I shocked before I left to 16.
    I left the solar cover on, held in place with water-filled bleach jugs (high winds here). I left my pump on low 24/7.
    I came back and all was fine. I was taking some chances with this but I was comfortable with the decision. Not everyone will or can make the same decision. Ideally, a friend/family member checking on things for you would be ideal. No reason to run the filter/pump more or less than normal, if you have a timer keep the settings the same, I would think.
    A solar cover reduces evaporation and protects the FC from UV rays so it will hold up better over longer periods. Also using an auto-chlorine feeder for these limited periods would help too....I would not recommend them for long term use, just occasional vacationization (I like that word - can we copyright it? )
    Oct 2007
    Cedar Hill, TN
    252
    We'll be gone for 2 weeks in September.
    I plan on putting the winter cover on, float a puck or 2 under the cover, and run the pump on low.
    Might shock it, too.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    11,969
    Quote Originally Posted by heikejohn
    I would absolutely shock it too, first.
    Jun 2008
    Marana, AZ
    347
    As long as the CYA levels aren't pushing the high end, I plan on shocking and putting a couple of pucks in the floater before we go on a short trip. If the CYA is too high for that, I will just come home to a green pool.
    I don't think I will leave the pump running; I would be afraid of it losing prime for some reason and ruining it.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mantua, NJ
    80
    Just came back from vacation without any problems.
    Yes the cover goes on.
    Timed interval, no change from regular settings.
    Not really. Always try to keep the water level correct and the solar cover will help prevent evaporation.
    Liquidator now, but before LQ: shock and pucks in the old Nature2 canister.
    Solar panels,,I turn off the heat.
    Neighbor will check skimmers for me.
    Before I added Borates to the pool, I always seemed to fight mustard algae when I would get back from a late July vacation.
    I also have my Cleaner setup to run under the solar cover.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
