Thread: Pool Cover question
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Pool Cover question
    My automatic pool cover is sagging and where it meets the shallow end it isn't flush with the wall. About 1 inch gap and about 6 feet long. Is this a problem?
    The water level at closing was just below the skimmer and it is frozen now. Been cold winter so far in Minnesota.
    30K gallon 20 X 40 IG vinyl built 8/2013, Hayward 1.0 hp super pump, 250,000 BTU Hayward heater, S244s Hayward Sand Filter w/side mount multi port valve, Hayward Aqua Rite Salt Chlorinator with Turbocell T-15 , Coverstar automatic pool cover with key switch, TF-100 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Cover question
    Welcome to the forum.
    Do you mean the cover has come out of it's track or groove? Any chance you can post a pic? It would help to be able to see it and someone can likely answer you better.
    Essential Links:
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Its not off the tracks, it is in the middle where it meets the wall on the shallow end. So when it is all the way closed the part that hits the wall. Its already dark will try to get picture on here tomorrow.
