Results 1 to 14 of 14
Thread: Replacing My Old STA-RITE Posi-Flo Pool Filter PTM 100
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    My filter is starting to leak at the bottom. The filter tank was installed in 2003 and the plastic is looking sun damaged. I am looking at Hayward and Pentair. Is one better than the other? Any others I should consider?
    Thanks
    6500 Gal. In Ground, Diamond Brite finish.
    Pentair 1hp pump
    Hayward C1200 filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Replacing My Old STA-RITE Posi-Flo Pool Filter PTM 100
    Welcome to tfp, MrPat
    All the major brands are fairly comparable.
    What size pool do you have? What pump size (model number) do you have?
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    The pump is a 1.5 HP Single speed Sta-Rite model MPFA6F-147L. Is there any reason to replace this when I buy the new filter? Are similar single speed pumps still available?
    The pool is about 6500 gal.
    Thanks, Pat
    Pentair 1hp pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    No reason to replace pump if it's working fine. You'll save money adding a 2-speed motor and running on low.
    You can get a 1.5 HP 2 speed for about $350.
    https://www.americanbestpoolsupply.com/ ... 129177.htm
    Here's a write up earlier: great-find-2ez-speed-75hp-square-flange-2-speed-300-t42909.html
    30,415
    If you decide to replace the pump, a 1 hp 2-speed will likely save you some electricity and be plenty large enough for your pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by MrPat
    Thanks, Pat
    For your small pool another 100 sq. ft. cartridge will be fine (though going larger won't hurt).
    As for the pump, yours appears to be a 1.5 hp full-rated pump, and if it is, it moves a lot of water, and it is quite large for your pool unless you have high volume water features such as waterfalls, massage jets, etc. Do you? No need to replace it if it is running fine, but if you do replace the motor with a 2-speed as bobo mentioned, you then can run on low most of the time and save some electricity...or you could follow duraleigh's idea and go with a smaller 2-speed pump which will save you even more running on low. A third approach is to replace the motor and impellor with a smaller "hp" size, and this would be like going with a smaller pump.
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    Thanks guys. When the motor dies I'll get a 1 up motor
    Pentair 1hp pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you mean pump here, then a 1 hp (or even 3/4) would be a good choice again assuming you have no high volume water features (do you?). If you meant motor, as in just replacing the motor on the pump, then if you decrease the motor size, you will also have to decrease the impeller size.
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    Thanks. The only water feature is a small spa. We never use the connected spa, but water does run into it and then into the pool via a "water falll". When I replace the pump I will replace the entire assembly (pump, motor, basket).
    Pentair 1hp pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Well if you ever want to use the spa, you probably do not want to go any smaller in pump size (may even want to go bigger for better jet action), so a 2-speed of similar size or a vs pump might make sense when it is time to replace. What does your electricity cost?
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    I should have mentioned that we have a separate pump we can turn on to use the spa as a spa. That would mean replacing the heater, which I'm not planning to do. We never use the.spa.
    Pentair 1hp pump
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    Thanks for the info guys! I now have a new Pentair single stage 1 hp pimp and a New Hayward 120 cartage filter. I just slammed the pool yesterday and the water looks great!
    Pentair 1hp pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sounds like your set...again we generally recommend a 2-speed pump when replacing since you will likely save significant electricity with with it over a single speed. What pump model number did you get?
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    SF-N1-1A/340038
    Pentair 1hp pump
