Thread: Testing used cell?
    Testing used cell?
    Hi,
    I have an old square aquapure cell in my pool, and got a used cell with the newer sized ports as a replacement.
    Before I change the plumbing, I'd like to know if there is a way to test the new cell. Would be sad if the new (used) cell turns out to be worse than the cell I currently have in place.
    x gallon
    IG, pebble-Tech
    Jandy DE filter
    x HP pump
    Installed 2007
    Spa and swim jets
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    Re: Testing used cell?
    Do you have a Leslie's Pool Supply store by you? The one by me has a tester for Aquarite SWG cells.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    Quote Originally Posted by Johnl
    Unfortunately, our Leslie's says they can test Hayward Aquarite, but not Jandy Aqualink.
    x gallon
    IG, pebble-Tech
    Jandy DE filter
    x HP pump
    Installed 2007
    Spa and swim jets
