Thread: SWG and Aluminum Furniture
    New Brunswick Canada
    819
    In everyones experience, will the salt in my pool erode Aluminum Furniture? I am asking, because my last cheap metal set basically rusted away to nothing.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: SWG and Aluminum Furniture
    In general, aluminum should be more resistant to corrosion then steel, though I would think how it is coated is probably more important. Was the corrosion near fasteners or all over the metal?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Were you putting the furniture in the pool, like on a tanning shelf? I have a hard time imagining enough pool water getting on the furniture any other way. We have aluminum furniture and salt water and have had no problems.
