Results 1 to 7 of 7
Thread: 1st pool quote.. Pearland TX.
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    So after meeting with 2PB's we have our first quote! Please let me know if we are missing anything or thoughts. We plan on meeting with several other pool builders but here is our first quote.
    We have decided not to go with a SW pool.
    Pool:
    width 17' length 36'
    depths 3.5-->6'
    gallons 17K
    returns 6
    bubblers 2
    tanning ledge 7X12
    12" raised beam with 3 - 24" scuppers
    Pool benches 2 ea 2X4'
    8' spa elevated 12" with stacked stone spillway
    Not sure on finish maybe go with quartz finish
    All Jandy Equip:
    -Fusion Nature 2 chlorine dispenser
    -CV series cartridge filter
    -LXi Pool and Spa Heater
    -Stealth pump with booster pump (should I request 2nd pump for water features bubblers and scuppers?)
    -Aqualink Touch (automation)
    -Nicheless LED lights
    - Mx8 pool cleaner robot
    Landscapping not included.
    $47,250
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    38,475
    Re: 1st pool quote.. Pearland TX.
    Nix the Nature 2. Using chlorine tablets is not a long term solution due to the stabilizer rise, especially is areas of little rain and where the pool is not partially drained for the winter. And it adds metal to the water which can lead to very expensive staining of the pool and turn your hair green.
    The only viable long term solutions to chlorinating you pool are:
    1. SWG ... which you apparently do not want
    2. Liquid Chlorine (either dosed manually every day or with an automated system like the Liquidator or a peristaltic pump)
    3*. Not really a good idea but, ... Using solid forms of chlorine and having to drain your pool fairly often due to CH or CYA rise.
    Start learning about the chemistry now:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Also, the booster pump is a 2nd pump ... likely for the water features. Ideally you could get away with a single pump as that will be the cheapest to run ... assuming you can find one sized for your needs.
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Thanks I will inquire about Jandy's watermatic chlorine system.
    It rains plenty here in Houston/Pearland Texas. From talking to friends in Houston that have SWG pools they say besides being tough on natural stone the salt water really eats away at their alluminum patio furniture which they had to replace every 3-5 years.
    Missouri City, TX
    73
    rodog123 -
    We live close to you - Missouri City (Sienna Plantation) and had our pool built in July / August 2012. We used Grand Isle Pools and were very happy with the work they did and the price was reasonable compared to other quotes we received. Let me know if you want their contact information.
    Steve
    20,000 IG WetEdge Satin Matrix Northshore Plum, Filled 8/24/12
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Quote Originally Posted by shuye
    rodog123 -
    Steve
    Steve YES! please send me their contact info. We are curently in the process of interviewing PB's.
    Our next meeting is with Platinum Pools this Saturday.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Quote Originally Posted by rodog123
    rodog123 -
    Steve
    I can second the Grand Isle Pools recommendation - they built my pool too and I am also very happy with them.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    Howdy - We are over in Shadow Creek Ranch - based on the bid herein above, i'd say we are both consulting the same pool builder. Would love to talk/trade messages! I'll even take you to coffee. PM me please.
    Pearland, TX build ongoing. Freeform pool with Spa. Estimate finish 1st week March, 2014
    Dimensions 37 x 24 x 17 feet. Spa is 8ft round. Approx. 20,000 gallons.
    Variable speed Jandy pump, Jandy Cartridge filter. Aqua pure salt water system. Polaris 280 (black) 3 LED Lights: 2 pool, one Spa.
    Pebblesheen. Blue Granite. Travertine decking and coping.
