Results 1 to 7 of 7
Thread: solar panel expectations
    Jun 2008
    Western NY
    12
    I'm wondering if any experts can help determine whether my expectations were too high on my purchase. I have (2) 4x 20 solar bear panels 12ft away from my 24' ag with approx. 13,500 gal capacity. I ran them for 4 hours in good sunlight (south facing) and was a bit diappointed to see a 1 degree increase. In the past, I've observed a 1 degree increase on 4 hours of sun prior to installing the solar panels. The panels appear to be plumbed correctly (I did it myself) and I followed the instructions from Fafco religiously. While the pump is running water through them, the panels feel nice and cool when compared to the adjacent roof surface. I shut it down for about 30 minutes and the panels felt warm. The air temp was about 68 degrees, the water temp was 70 (using a solar cover religiously) and got to 71 before we lost sunshine that day.
    If this seems correct, then with 4 hours of pump running to circulate water through the panels to gain 1 degree seems that on a full sun day for 10-11 hours (pool and panels are in full sun from dawn to dusk) I should only see 3 or 4 degrees??? I was hoping to see 10- 12 degrees.
    Any input would be appreciated.
    Thanks
    Oct 2007
    Valrico, FL
    542
    Re: solar panel expectations
    How many square feet is the surface of your pool? Mopst recommendations is to have the solar panel area about 50 to 100% of the area of your pool. With two 4x20 panels you only have eighty square feet of solar panels. That is not much. I have an inground pool, 7500 gallons and have 240 square feet of solar panels. And I am in Florida! I would say that you need more panels.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Jun 2008
    Western NY
    12
    ...80 x 2= 160sf of solar panel. A 24' circle is about 452 sf. With that, I'm way undersized. I read that (1) 4x 20 panel would heat a 24' pool.... I don't remember where this came from. It may have been a website selling panels. Would that be a marketing scheme? If they told me to buy (9) solar panels at $240 each, I would not have done it. There just isn't enough sunny days up here to utilize a solar system if the cost is $2000 or so.
    Thanks for your input.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The recommended sizes are of dubious value. Most of them are based on the idea of nearly year round pool operation. The panels you have should be able to make a noticeable difference in your pool. I suspect you are asking a lot with air temps that low and such a short day of sunlight.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    If your air temp was 68, in my limited experience you won't see too much gain. I have 160 sq ft of panels for a 16x40 IG pool. We had a cool season so far, and I struggled to get into the high 70s for a while. We had a really hot weekend a few weeks ago and I went from 70 to 85 in 2 days running the pump during the day with the solar cover on. When its nice and warm/sunny out, standing in front of the return, I can feel the warm water. It does help keep a constant temp, I haven't gone below 80 since that weekend, and we have had cool days and colder nights since (single digits!)
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Just be sure to remember to drain them in the fall (don't ask how I know...) .
    27' AG round pool; vinyl liner; 1 HP pump; 40 GPM Tagleus sand filter
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    We've got 3 2x20 panels mounted on our south facing garage roof for a total of 120 sq. ft. The panels get full sun from 9:00 a.m to 5:30 p.m. and on a good day like today (full sun, 90* air temp) they heated our pool (5700gal) from 78* to 89* with a solar cover on. If it's sunny tomorrow I have no doubts it will be in the high 90's and I can gaurantee I will not want to get out.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
