Thread: Pool Has Leaked Out Since Closing
    Mar 2013
    Western KY
    14
    I partially drained (below skimmer and return lines) and closed my pool at the end of September/ early October, and I realized yesterday that when I went to pump the water off my cover, that the pool is now basically empty. I first guess is that I have a leak in my floor drain line. I know I did not have this problem last year. My wife and I just received an offer on this house and expect to have a contract soon. Am I looking at a huge repair bill? I have a vinyl liner and I am afraid to remove the cover to see what kind of shape the liner is in. Insight and advice is greatly appreciated.
    18k Gallon In-ground, vinyl liner
    Sand filter
    1hp one-speed pump
    Mar 2013
    Western KY
    14
    Re: Pool Has Leaked Out Since Closing
    Bump.
    Looking for any advice here I can get. This has me really worried. By rough calculations I am estimating that I have roughly a 100+ gallon a day leak somewhere either in my liner or in the floor drain line. Will the liner be affected detrimentally by the pool sitting empty until spring? I am in uncharted waters here.
    Sand filter
    1hp one-speed pump
    30,424
    I certainly read your first post yesterday as I'm sure did many others. It's been hard to offer a definitive solution.
    I believe that your first step probably has to be positively identifying the source of the leak........which may involve removing the cover.
    I can't see how you can make much progress until you determine the source.
    Sep 2013
    Auburn, Alabama
    73
    If the pool is already almost empty any way plug the drain.
    Then fill it up with a couple feet of water above the drain and monitor the level.
    If it continues we know the liner has a hole or holes, which is the most likely culprit.
    How old is the liner?
    The Original Leak Specialists.
