Results 1 to 7 of 7
Thread: Suggestions for leak at Pump
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Hi guys, I just bought a house with a pool, but it has a leak at the pump. It's one of the lines that runs to the filter. Attached are pictures of the leak.
    I was thinking of some putty or sealant for PVC pipe. Would that be OK?
    15' x 30' Oval In-Ground 13,500 Gallons, Built 1979, Millenium 27" Sand Filter, Centurion 2HP 56-Frame Pump, Dolphin Deluxe 4 Pool Cleaner
    30,426
    Re: Suggestions for leak at Pump
    Welcome to the forum.
    Your pics didn't show up. If it's on a line going from the pump to the filter, there should be only one line and, unfortunately, it will be a slightly harder fix than just putty
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Thanks for the response, that doesn't sound good. It is on that line. Working on a Cell phone, unfortunately the cable guys are always the last to come in a move
    Smykowski's Avatar
    Sep 2011
    3,065
    Looks like the pipe dope is old and failing. Not sure if you can just undo the pipe from the pump and clean it off. You may need to undo the union and replace the segment between the pump and the union. Wait for other opinions to see what the plumbing experts have to say.
    30,426
    Yeah, smykowski has you covered with good advice.
    Unscrew the union (smart guy that put it there), There's an 0-ring inside the union, don't lose it.
    Then unscrew that pipe assembly from your pump.
    Remove all traces of the old pipe dope on both the pump and the pipe....especially down in the threads.
    Then simply remake the joint by evenly spreading a generous layer of pipe dope on the male threads and screw it in.
    Screw it in carefully so you arrive at a point where the joint is snug and the union end of the section lines back up with the other side of the union. Hand tighten is all you need.
    Wipe off all the excess pipe dope on your new joint so it will look nice and professional.
    marcellus7's Avatar
    Nov 2013
    San Antonio, TX
    15
    Thanks for all your help guys, I really appreciate it. I went and got done of the PVC cement, but I can't get the union to screw for the life of me. What do you his think I should use to get it off? I'm sure it's got glue on it already on
    Smykowski's Avatar
    Sep 2011
    3,065
    Yeah, that was the other thing I noticed. Unions shouldn't have pipe dope on them. There's an o-ring in there that gets the job done.
    Put an old rag over the union to protect the plastic, then use either channel locks or a pipe wrench to get a little leverage. Go slow, though. If you don't break the seal, you'll break the union.
