Thread: What parts do I need for intellitouch automation
    I am looking at replacing my main pump with a vs pump and looking at the VF intelliflo. Right now I have the Jandy RS8 controller wired into the bedroom to control the system (waterfall pump, filter pump, spa pump and pool light).
    I am trying to research what components I need to help prepare a budget. I don't want any wireless or iPad systems, I would be happy with another wired controller installed in place of the handy RS8. I understand if I stuck with the Jandy RS8 I would need a different circuit board or adapter to control the pump through the Jandy controller.
    Could my fix be as simple as replacing the RS8 with the intellitouch and some wiring or is it more complicated?
    - thanks - Tom
    Re: What parts do I need for intellitouch automation
    I don't know what the Jandy RS8 controller is like, and, or if you are unhappy with it.
    But as another option to changing your Jandy controller, there is this option available;
    a "Pentair 521109 IntelliCom II Interface Adapter", it accepts four inputs (9 to 24 volts AC or DC) and
    controls the intelliflo pump by sending the respective RS485 commands to run four pre programed speeds or flows.
    I will be installing one of these next week in my pool system as a stand alone controller of the VF pump, so I will be able to provide addition feedback later.
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    The problem with the aqua link RS8 is that there are no settings for controlling the variable speed properties of a VS pump. So I am not sure what parts would be needed to link a VS pump to my existing system. I don't understand why they ssell circuit boards to upgrade the RS8 - I am assuming for some reason you cannot just stick a new controller in there - that would seem like a better option than attaching a circuit board to the RS8. I am not planning on installing this myself but I am trying to understand my options.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by tomsop
    Could my fix be as simple as replacing the RS8 with the intellitouch and some wiring?
    - thanks - Tom
    Yes you can do it that way.
    Or...
    If you are happy with the Jandy controller, another option, if cost is an issue, is to instead of the intelliflo pump, go with the Jandy equivalent. VS FloPro, or ePump. Providing you have the correct firmware revision on the RS unit. It must be Rev. O or newer. This way, the only cost/purchace is the pump.
    How to check your RS REV:
    http://www.nuccibros.com/sec_0934drRb_d ... 0ePump.pdf
    Start on page 6
    Factory Warranty Station for:
    I am not happy with the Jandy Aqualink because it is my understanding was that the Jandy could not control VS pumps - are you saying that with the firmware upgrade I can control a Jandy VS pump? I may be interested in that solution.
    I will have to research the Jandy pumps - on Amazon the e-pump gets a good review (not many reviews) and there are a couple bad reviews of the flopro (also not many reviews). It seems the e-pump is cheaper than intelloi-flo - I will have to look into this option - thank you for your reply.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    I do little, if any cross manufacturer integration. I would call Jandy first to see if their iQ900RS upgrade will talk to the pentair variable pumps, before you make that investment. Not that i wouldn't trust anyone here that may know, It's a lot of money to invest with no recourse if you take our word alone that it will integrate!
    Good Luck.
