Results 1 to 13 of 13
Thread: What is that in my pool???
    Jun 2007
    Indianapolis
    14
    We finally have a sparkling pool after a long battle with algae. The water is crystal clear and we were finally enjoying our pool! We came home yesterday from work to find "soapy looking" bubbles all over the pool. We have some air in our lines and need to have some pipes replaced (next year) so the jets do produce some air bubbles, but they have never turned into sudsy bubbles before. What is causing this? Has anyone seen this before??
    20x40 In-ground Vinyl liner with no swg yet and no heater approximatley 25000 gals
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: What is that in my pool???
    What kind of sanitizer do you use? I've seen soapy bubbles in a Baquacil pool.
    Could you post details about your pool and filter setup and a set of test results? It will also help to know what all you've put in the water in the recent past.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Jun 2007
    Indianapolis
    14
    We have a 40,000 gallon gunite pool with a sand filter. We just treat with bleach as we don't have an automatic chlorinator. A few weeks ago our alkalinity was 180 so we added some muratic acid. That's really it. Not much going in there.
    FC Chlorine 3+
    PH 7.2
    Alkalinity 110
    AnnaK's Avatar
    Jul 2007
    1,134
    I'd love to have a 40,000 gallon pool!
    Can't help you with the soapy bubbles questions, I'm sorry. but someone else will surely pick this thread up and have some ideas.
    AnnaK
    Jun 2007
    Indianapolis
    14
    The pool is huge and we love it.....when it is behaving! It needs a lot of remodeling and TLC. We've only been in the house for a year and a half and already sunk a ton of money into it last summer when a pipe completely ruptured and caused our neighbors yard to be flooded! Someday it will be quite the oasis.
    AnnaK's Avatar
    Jul 2007
    1,134
    But you're way ahead of the game by using BBB! Think of the money you'd sink in if you were buying at the pool store.
    I'd like to suggest that you add your pool's specifics as a signature block. You do that in the User Control Penal. That way, someone coming to the thread late doesn't have to ask about pool and equipment because it'll be in your sig at the end of each post.
    Have you added any algaecide? I read that some of those products can cause soapy bubbles.
    What kind of test procedure do you use? Reagent based drop kit? Strips? Pool store? Are you able to test for CYA?
    AnnaK
    AnnaK's Avatar
    Jul 2007
    1,134
    I did a search on " +soap* +bubble* " and found this thread: http://www.troublefreepool.com/soapy...uds-t1763.html in which it's said that algaecides can cause soapy bubbles. Also a nascent algae bloom, and low pH. You said your pH is at 7.2 because you had just done a muriatic acid treatment to reduce TA. I don't know what the recommended pH is for a gunnite pool. Have you researched the Pool School (link above in the logo menu bar) for chemical balances for your pool?
    AnnaK
    pH is basically the same regardless of your pool surface... mcgolf's is at the low end of acceptable.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2007
    Indianapolis
    14
    We haven't put any algaecide in the pool. We use a reagent test kit, but it doesn't test CYA. Only TC, FC, CC, PH, Alka. This morning we turned the pump off and let the pool sit. All of the soapy bubbles are gone. It is something with the few bubbles the jet is blowing coupled with hitting the water. When the bubbles come out of the jet, they are clear, when they surface is when they are sudsy looking. Bizarre!!
    Very low CH levels sometimes cause bubbles or foam.
    Shelley N's Avatar
    Denver, Colorado
    199
    Could it be summertime boredom by some local kids? "Hey, let's put some some soap in the neighbor's pool".
    I've seen an increase in stupid thinking by my son's 14 year old friends.
    Shelley
    Denver, CO
    Jun 2007
    Indianapolis
    14
    Well like magic the soapy bubbles are gone this morning. We left the pump off yesterday and turned it on last night and nothing has formed. Still some air but that's it. I'm telling you that pool has a mind all its own!
    AnnaK's Avatar
    Jul 2007
    1,134
    I agree. Pools are some sort of weird life form with near total control over our time and money
    Glad yours solved its own problems.
    AnnaK
