Results 1 to 9 of 9
Thread: Installing a safety fence in travertine?
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    Has anyone out there installed a pool safety fence in a travertine deck? If so, how thick was your travetine? Did you have any issues with instability or otherwise?
    Thanks in advance!
    Build Complete! : 111ft pool + 8.5x5.5ft spa (12" raised), ~22k gallons, Shotcrete, Stonescapes MiniPebble (Aqua Blue), 3 scuppers, 3 bubblers, Large Tanning Ledge, Long Bench, Pentair: Intelliflow 3050 VS, 1.5HP WhisperFlow (scuppers), Quad 100 DE filter, MasterTemp 400k, IC60 SWG, Intellichem+Acid Tank, 2HP Silencer Blower, travertine decking (~680ft2), dry stack flagstone raised wall / spa spillway
    30,426
    Re: Installing a safety fence in travertine?
    Of course, travertine by itself is incapable of the strength required to hold a fence. (as is any surface material) I assume you have a solid 4" concrete slab under the travertine, correct?
    Give us a bit more info.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    We don't have anything yet. We are looking to sign a contract in the next week, and are trying to figure out which kind of decking to put in - travertine or stamped concrete. We want to put in a safety fence, but I am concerned about travertine's ability to hold it steady. I think most just lay travertine on sand. Pool fence websites say they install them in travertine, but I have not been able to find much in the way of details on the topic.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If they lay it on sand then yes you will probably have problems much like how safety cover anchors will pull out pavers when installed incorrectly. With safety cover the anchors are to be installed in the joints between the pavers usually using pipe in anchor. Its all about getting into solid ground
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    30,426
    Installing travertine as pavers on sand is quite a bit different than grouting travertine and installing it on a subsurface of concrete.
    In either case, a fence can be put through it but think in terms of the fence being anchored from under the travertine rather than in it. The fence post would only pass through the travertine and not count on travertine for any structural support.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    To add to what the others have said, the pool safety fence (at least the katchakid version which is what we have) needs at least 4" of concrete. We looked at running ours over grass and it needed concrete footings every 3'.
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    Thanks all. I wonder if they could easily put concrete footings under the travertine where the posts would go.
    If your sold on the travertine then yes, they can put some footers in. Our fence extends into the grass on both sides of the pool and they just dug a hole and poured some Quickrete. It's solid, a cheap solution and the fence is really secure - so you can get the best of both worlds.
    New Pool: 22 x 35 | StoneScape Mini - Midnight Blue | ~17,500 gallons | Jandy Equipment - Built spring 2015 (click for details and pictures)
    Old Pool: 16 x 30 | QuartzBrite | 14,000 gallons | Pentair Equipment - Built summer of 2013 (click for details and pictures)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    They can install a deeper anchor pipe, just like they do for safety cover anchors. Our pavers are not travertine (3" concrete) but that's what was done for ours.
