Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: My First Pool
    My First Pool
    Hi All, as indicated, this my first pool. Just moved in and the previous owner said he "Just knew what to do; dumped in a 1/2 gallon of 10.5 chlorine every week". Also kept 2-3 3" large chlorinating pucks in a tube that, I assume pool water circulated thru when the pump is running (about 8 hours/day). I have a TF-100 test kit. Please advise.
    FC 36 CC 0 TA 50 CH 260 CYA 100
    Thanks a ton!
    Dan
    Dan 14K plaster IG caged pool in Fort Myers, FL Pentair SuperFlo VS Pentair cartridge filter Pentair UltraTemp 110 heat pump Pool Pilot Nano SWG Great White Suction cleaner TF-100 Speedstir
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My First Pool
    Welcome to tfp, maryspoolboy
    Quote Originally Posted by maryspoolboy
    You did not post your ph?
    How does your water look?
    A cya reading of 100 with the tf-100 kit may actually be higher. I would do a 1/2 pool water 1/2 cya free water (tap water is fine) and redo the test. Then multiply your result by 2. Getting the cya down is probably your first step. If there are still pucks in the feeder, take them out.
    38,284
    Re: My First Pool
    Welcome to TFP!
    For the CYA test, was the water well below the line? That would mean it is much higher than 100ppm, which is already too high.
    Your FC appears way high, did you use a 10ml water sample and used 72 drops?
    First step is to lower the CYA by replacing at least 50% of the water. All those tablets have raised it too high.
    Re: My First Pool
    Sorry pH is 7.2
    I took out the pucks even before I registered.
    Yup, 10ml
    Re: My First Pool
    The water is crystal clear. I'm ready to jump in but that FC scares me
    38,284
    Re: My First Pool
    Actually that FC is perfectly safe since your CYA is so high.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My First Pool
    Do you know why the FC is so high?
    We view swimming up to your shock level as safe...which in the case of 100 ppm cya is 39 ppm FC. See: http://www.troublefreepool.com/pool-...ya_chart_shock
    Re: My First Pool
    I assume the FC s high from the chlorine he had been pouring in there without testing. And the pucks?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: My First Pool
    pH is likely skewed as it does not test correct at levels over about 10 ppm FC, personally I would dump half the water refill and go from there. (note there is danger of pool floating (popping out of the ground) if you drain too much at once and have a high water table, so if you have a high water table you might want to remove 1/4 of the water, refill and repeat.
    Ike
    p.s. note that without using the dilution method the CYA test is only good to read up to about 100 ppm, so your CYA may be much higher
    oopps auto correct strikes again
    Re: My First Pool
    I didn't think cement/gunite/plaster pools were at risk to pop out of the ground. I thought that was more of a risk with vinyl or fiberglass pools?
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    My First Pool
    Hey Everybody, Happy New Year! I just tested again and it looks to me like it's coming around. I haven't added anything, other than fresh water. I just let the hose run in it for most of a day. Here's where it was and where it is now. Please advise me on where to go from here. The water looks sparkling clear with no evidence of algae. It's a pleasure to swim in, with odor of chlorine or anything else.
    12/13/13 1/1/14
    FC 36 FC 25
    CC 0 CC 2
    pH 7.2 pH 7.5
    TA 50 TA 70
    CH 260 CH 375
    CYA >100 CYA 55
    I appreciate the advice, and I will have more time now, after the holidays, to read more of the info on this site.
    Thanks again,
    Dan
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: My First Pool
    12/13/13 1/1/14
    FC 36 FC 25
    CC 0 CC 2
    pH 7.2 pH 7.5
    TA 50 TA 70
    CH 260 CH 375
    CYA >100 CYA 55
    Thanks again,
    Dan
    Question: how big a sample are you using for FC, and what are you multiplying the drops by? 25 is above shock level for 55 CYA, and should be rough on the eyes and swimsuits if correct. Also note your pH reading will be wrong if the FC readings are correct. CC looks high, but many water companies use chloramines to disinfect and prevent corrosion, so if the water is clear and the number dissipates, it's nothing to worry about. Is this a continuation of some earlier thread? If so, try to keep things together. It's easy to lose track of things. In the summer, we might see 200 new threads a day.
    Re: My First Pool
    For the FC, 10 ml, 50 drops multiply 0.5 = 25 I may not be doing the CYA test correctly
    Sorry, i don't know to do the thread thing. Should I have just replied to my previous post?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    My First Pool
    How did you do the CYA test ? You want to it in full sun with your back to the sun and the sample at waist high. When the black dot disappears take your reading. Also if your pool water temp is low bring sample inside to get to room temp.
    The reason to keep everything under the same thread you started is so everybody can follow the history better and see your previous posts. It just makes things easier.
    Jeff
    Re: My First Pool
    OK, Jeff, thanks. Previously I did the the CYA test as you described. this time I was facing east, so the sun was on my right. It makes sense that lighting would have a significant impact. I will re-test CYA tomorrow
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: My First Pool
    Yep you got it. The test is light sensitive.
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: My First Pool
    Topics/posts merged--------your friendly neighborhood woodyp!
    Re: My First Pool
    Hi All, Finally got around to testing again. It's been a little chilly here for swimming, so I didn't test til today. The water has remained crystal clear and sparkly.
    CL 7.5
    CC 0
    TC 7.5
    pH 8.2
    TA 70
    CH 350
    CYA 80
    I'm guessing I should add some acid? How much and in what form? Any other thoughts are welcome
    Dan
  20. Back To Top    #20
    22,548
    Re: My First Pool
    You can use poolmath (there's a link at the top of the page) to find out how much acid you should use. We prefer muriatic acid for pH adjustments.
