Results 1 to 8 of 8
Thread: Maximum safe FC level
    Hi... anyone know what's the maximum FC level that is still safe for swimming?
    18,500 gunite/pebble plaster, Taylor K-2006 test kit, Jandy 2hp variable pump, cart. filter, ozone system, in-line-chlorinator(not in use), borates, Polaris 9400
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Maximum safe FC level
    Quote Originally Posted by jbinbali
    Up to SLAM level based on your CYA.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by Smykowski
    Welcome!
    To expand on that a little... the safe FC level depends on the CYA level. If you have no CYA, figure 10 FC is as high as you can go. And I would expect that to be rough on eyeballs and bathing suits. If, however, your pool has been overloaded with CYA from years of using trichlor pucks and weekly "shock" per the pool store, you could probably swim in 50 FC with no problem. Check out this chart in Pool School:
    pool-school/chlorine_cya_chart_shock Anything up to shock (SLAM) level is safe.
    In fact, there's a ton of information in You can learn our lingo by reading the articles in there.
    Smykowski's Avatar
    Sep 2011
    3,065
    Jeez, my bad. Didn't see it was your first post. Welcome to the forum!
    Tapatalk makes me brief, but Richard picked up the ball I just dropped.
    Tks so much... really helpful. I have to own up and tell you I live in Bali. I have a tiny tiled concrete pool (about 10,000 ltr) but it's been a nightmare trying to keep it clear of algae. My major problem (besides trying to communicate technical terms and chemicals in the local language) is there are no decent test kits here, just the basic. So what I'm going to try is to shock it to the max level (FC 10 - its relatively new water and never been properly shocked before so CYA 'should be low' ), if that turns from green to light blue or white then continue to keep it at that level for a few days then flock it and start again. Of course the Ph and TA will be checked (the TA is low - about 60 however finding baking soda here except in 50mg containers is a challenge), the sand in the filter is new and I'll be constantly brushing the pool while shocking it. Wish me luck!
    38,371
    Do have the pink DPD chlorine test or the yellow OTO chlorine test? The pink one can bleach out at high FC levels so you think it is low when it is not. The yellow one just turns orange and brown at the higher FC levels, so you have some clue how high it is.
    So, hope you can get the OTO one as that is a little better ... Although far short of the recommended FAS-DPD test.
    And a TA of 60 is fine.
    Yeah I've got the OTO (yellow one), and great to know TA is ok as it seems most of the info I read says it should be around 100... thanks again
    38,371
    The only reason to raise the TA that high is if you were using Trichlor tablets, which we do not recommend.
