Thread: Height of waterline tile?
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    I am an architect designing a pool for a custom home. We found a nice large format tile from the Netherlands that we would like to use for the waterline tile. The manufacturer confirmed that it will work in a pool. It's dimensions are 3.75" high by 23.5" wide. My questions are:
    1. What is the recommended height of waterline?
    2. Why must we have waterline tile? Is it possible to simply run the pool plaster all the way up to the underside of the coping?
    Thanks in advance for you help!
    Pool Size: 9,000 gallons
    Pool Type: In ground, plaster
    Filter: Pentair 4000 Series D.E. Filter
    Pump: 1 HP Pentair Whisperflo WFE-4
    Heater: Sta-Rite Max-E-Therm 200
    Salt System: ECO-matic ESC 36
    Pool Cover: CoverStar, motorized cover
    38,537
    Re: Height of waterline tile?
    1. Usually, the tile line is 6" tall ... I think that is what you are asking. Although you could make it whatever height you want.
    2. Plaster is not meant to be exposed to the elements (air/sun) ... some pebble products have no issue with the exposure. There will always be line of mineral deposits around the surface of the water due to evaporation, especially if your water is high in CH. I would imagine that this would be more difficult to remove if it was not on tile.
    If the pool is not straight sided, I would imagine that a 23.5" long tile is going to cause issues unless you plan on cutting it a lot. Even my 6" tile required some cutting for some of the curves in my pool.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Thanks for the response. We found that they produce a tile that is 8" tall by 48" wide which will work very well for us. And yes, the pool is a rectangle with straight sides. Thanks again for the information.
    Oct 2016
    Atlanta
    1
    Quote Originally Posted by Elgrecus View Post
    Which large format tile product did you end up using for this application?
