Results 1 to 7 of 7
Thread: How to start following TFP method?
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    I want to do my my own chemical testing and am going to use the site suggestion on BBB. What's the first thing I need to do after I buy the 3 B's.
    I just received my TF-100 test kit 2 days ago in the mail. After I call and cancel the service, I'm going to start the year off right and do it myself. I can pretty much handle any plumbing issues that come up, but I'm far from a being a chemical expert after all these years of owning a pool.
    I checked my local grocery store today and they carry everything I need, I found the bleach at over 8%, so that should work for now.
    What's your suggestions? The water here is very hard in the desert area around Las Vegas, NV
    I'm still working on my signature for what the water test shows as of now.
    Thank you
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    38,507
    Re: How to start following TFP method?
    First, we are working to switching from calling it the BBB method to the TFP method because (as you are an example) people think they need to buy all 3 of the chemicals.
    You need to realize that what we teach is to only add what your pool NEEDS based on your test results. So, generally it is not a good idea to stock up on any chemicals (except maybe bleach). Many members (myself included) NEVER need baking soda or borax.
    So, run a full set of tests using the test kit that you have and we can then figure out what you should do going forward.
    Here are some more detailed instructions: Extended Test Instructions
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    You probably won't need baking soda and borax is totally optional, and I advise against it until you get used to balancing everything without it. Why confuse things with an extra variable?
    If a service has been maintaining the pool, you will probably discover the CYA is too high. Because you live in Vegas, the CH will also be way higher than the recommended levels. You'll have to accept that and live with it. If you haven't read extended-test-kit-directions-t25081.html yet, do so. Especially study the CH and CYA test directions for high CYA and high CH.
    Post a set of numbers and you will get advise on what to do. Don't just test, plug in the numbers, and start dumping chemicals in based on some arbitrary target. You might need to drain some water, or you might need to use some different target adjusted for your situation, so be patient.
    30,431
    Your very first step is testing and posting the results here. You can only determine what you need to buy (if anything) as a result of posting test results
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I agree with everything said above. Good advice from some of the best !
    Jeff
    Mark R's Avatar
    Nov 2013
    166
    Thanks ! I'll post chem numbers soon
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
