Thread: Frustrated.
    Jul 2012
    Bel Air, MD
    52
    Frustrated.
    Hello all,
    I forgot to put chlorine into the hot tube for a couple of nights and when I next checked, of course the CCs were high. So I started shocking the pool. Right in the middle of the shock I had a death in the family and needed to travel to the funeral. My wife trying to help in my absence, over chlorinated the water. My target shock level is 10ppm. My wife had it up to 20ppm. Today is the first day where it dropped to < 10ppm since I returned home 6 nights ago. I still have CCs of greater than .5ppm. It has been 6 straight days of > shock levels of chlorine and the bacteria is still not gone.
    I have to tell you that this hot tub was a "tester" for a real pool and it has been anything but trouble free. I have frequently dumped the spa water and started again. Each time I waste 300 gallons of water, but shocking the water and fixing this bacteria problem has been a constant challenge that I have faced over and over again. In the last year, I have spent more time fixing the bacteria problem than I have enjoying the water. I am sick of it.
    I would switch to bromine in a heart beat if I had a clue how to do it. I invested so much time reading and researching how to take care of the water - I understand the testing and treatment procedures recommended on this site, but frequently forget to put in chlorine. The water is so sensitive that if I forget one night there is a good chance that my water has bacteria - if I forget two nights in a row - then my water definitely has bacteria. In a 7 day period I probably forget at least once if not twice and so rarely have water that can be used for more than a week or two at the most.
    I am dumping the water again tomorrow - another 300 gallons going to waste and I haven't used the tub in over two weeks waiting for the bacteria to die. I was so excited to get the hot tub - but now after a year of fighting to keep the water usable, I am so frustrated that I hate even talking about it.
    I will never get a real pool.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Frustrated.
    Really sorry to hear you're having such a hard time, but it sounds like you know exactly where theproblem lies:
    Quote Originally Posted by Garet Jax
    ......but frequently forget to put in chlorine.
    Unfortunately, "trouble free" does not mean "maintenance free." Pools are like pets - you have to play with them even on days you really don't want to.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Frustrated.
    I also agree the frustration lies in forgetting to add chlorine. Not the hot tub's fault !!
    Jeff
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Frustrated.
    If you want more automated dosing of chlorine in between soaks, you might consider the ControlOMatic Technichlor saltwater chlorine generator.
    Your other option is to use bromine tabs in a feeder following the 3-step bromine procedure described in Using Bromine in a Spa.
    By the way, having some CC in a spa is not unusual. It's not like a pool where one can often expect 0.2 ppm CC. If you have 0.5 ppm CC it may be OK, especially if you don't smell chloramines. The CC may be chlorourea which is fairly innocuous.
    Does your spa have an ozonator? If so, then that uses up chlorine faster in between soaks since ozone reacts with chlorine. That makes maintenance with chlorine even more difficult.
    38,305
    Re: Frustrated.
    From what I have read ... it seems to me that maintaining a spa is MORE difficult than maintaining a pool actually. The pool has a lower bather load and the greater volume makes the chemistry less error-prone (meaning it is harder to drastically over-shoot things).
    The advantage of a spa is that it is ONLY 300 gallons to drain and start over ... that is only a few dollars of water. And spas are such that regular draining are almost a requirement, where as a pool there is rarely a need to drain and start over.
    The same is true of fish tanks ... the smaller the tank, the more difficult it is to keep the water in balance.
