Thread: Is it easy to install a pump timer?
    My set up:
    230v pump which plugs into an outlet. That outlet is controlled by a standard switch. I don't have a lot experience with electrical projects, though I did replace my pool pump last month (but that was easy because I just used the old wiring and it was an exact match to the new pump). I was in Lowe's last weekend and was looking at one of the Intermatic mechanical timers and read the wiring schematic. Unfortunately, that made me more confused. Is this a project that I should just hire someone to do? I would think it would cost more to have someone come than the timer itself!
    Thanks in advance.
    30K gallon, In-ground Gunite
    Central NJ
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    Re: Is it easy to install a pump timer?
    I've wired them myself, but I do have some DIY electrical experience. They way mine is wired, is from the pool house panel, into a standard switch, then out to the timer and solar control. That way with a flick of the switch, the entire system is off.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    We hired an electrician. The pump and lights/electrical outlets have their own breakers at the box in the basement. He wired the timer to the pool breaker and mounted it on the wall. I can manually control the timer or I can shut the pool down on the breaker.
    — AnnaK —
    12,000 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
