Results 1 to 10 of 10
Thread: electrics
    May 2013
    Cyprus
    159
    electrics
    Hi
    Can anyone tell me why my supply to my pool motor is wired via a contactor. Yhe supply is fed from a fuse board in the house to a fuse board in the pool room via a rcd the to a contactor then to my pump motor.
    Thank.
    Living in Cyprus
    Still enjoying life
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: electrics
    Most likely for some kind of automation or possibly an anti-entrapment device.
    22,548
    Re: electrics
    Does the pump have a start/stop button or timer on it? If not, then I suspect JT is right.
    May 2013
    Cyprus
    159
    Re: electrics
    The pump is hard wired to a 13 amp plug which is plugged into a timer which is plugged into a socket. The socket is wired from the contactor What is an anti-entrapment device?
    Living in Cyprus
    Still enjoying life
    SW Indiana
    9,199
    Re: electrics
    Quote Originally Posted by bof
    An anti-entrapment device shuts the pump down if it detects a blockage of water flow on the inlet side of the pump. It prevents people from being held to a drain or other intake by suction.
    May 2013
    Cyprus
    159
    Re: electrics
    WOW Thanks for that I did not know the suction was that powerful. I will check it out when I start using the pool next season. But other than that I can safely run the motor without the contactor.
    Living in Cyprus
    Still enjoying life
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: electrics
    Not sure what you mean by "check it out", but please recognize that the main drain can be very dangerous. The need for anti-entrapment, is because people have sat on drains and instantly had their internal organs sucked out of their bodies. Not a pleasant way to die.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    22,548
    Re: electrics
    Can you post a picture of the contactor?
    Jun 2012
    western NY
    1,560
    Re: electrics
    Are you sure it is not a circuit breaker acting as a disconnect device? A contactor usually needs a power source to energize it from, say, a push button start stop, or some other input signal.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2013
    Cyprus
    159
    Re: electrics
    Yes it is a contactor and it is energised from the mains supply. Thinking about the cct and the standard of electricians the cct has probably been copied from an early site and wired up the same but did not know why. Monkey see monkey do. Their is no anti-entrapment device, and my idea of trying it out is to put my hand on the drain to see for myself the suction but not until next year when the water is a tad warmer. Sorry no photo i.e. no camera and a bog standard mobile phone. To put it into context the standard of buildings on this island is criminal, but it is deemed your fault for buying it.
    Living in Cyprus
    Still enjoying life
