Thread: I think my freeze protection isn't working
    Jun 2013
    Dallas, TX
    105
    I've got a Compool CP3600 control panel. Anytime it detects temps below 35, it would kick into freeze protection mode in years past.
    Last few days in Dallas have been super cold. I've just had the pool in service mode and running, but decided to see if the freeze guard would work. Put the pool back into auto, and it's registering 34 degrees (when I turn the pool on) but the freeze guard never kicked on.
    The panel isn't throwing any errors, is there a way to troubleshoot this?
    35k gal, sand, IG, diamond brite, Hayward Goldline T-CELL-15 Turbo SWG, Aquarite, Compool Lx3600
    Jun 2013
    Dallas, TX
    105
    Re: I think my freeze protection isn't working
    Anyone with an idea here? From what I've read it should throw an error if the temp sensor has gone bad. Not seeing that though.
    mas985's Avatar
    Pleasanton, CA
    11,737
    This is one of the main reasons, that I do not believe anyone should rely on freeze protection. If it is that cold (average 24hr temps < 32F or min temps < 20F), then I would drain the pad equipment and let it sit idle.
    Mark
    Jun 2013
    Dallas, TX
    105
    Keep in mind I'm in Dallas. This is not a normal thing.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I know you are in Dallas and I wasn't suggesting that you close the pool. I am also in an area that gets below freezing weather so I have had some experience operating a pool during very cold weather. I am just suggesting that to prevent freezing, you are much better off draining the pad equipment and it is very easy to do if the equipment is above water level. Just remove the pump lid and the pad equipment pipes should drain. Usually, the filter will drain as well. If the filter doesn't fully drain, open the pump drain plugs and that should force the filter to drain too.
    Mark
