Thread: automatic water leveler connections
    New to this site, but I like it very much.
    IG already built, with no provision for automatic water filler. I have access to the full length of one of the return lines. I cannot drill additional holes in the pool walls. my question: Is there any possibility to share this return line with auto-water-filler output? I mean working as a return at the same time! How to prevent the sucking of water from the external leveling container.
    Thanks for any comment/suggestion.
    Lennyf
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: automatic water leveler connections
    Welcome to TFP!
    You could potentially add water that way if you could figure out a way to make it safe to avoid contamination of your tap water. That's not trivial. The biggest problem is the need for a float to control the valve.
    30,421
    I think I might be tempted to just fill the pool manually. Autofills are certainly convenient but they can mask a leak in your pool. If it ever does, that usually causes far more inconvenience than the autofill saved you in work.
    I tend to be a minimalist anyway, but I would prefer to fill my pool manually as I don't see it as that much effort.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    For what it's worth I totally agree. I had an autofill installed with my pool remodel and the worries of having it stick open when you're not around and the inability to foresee chemical additions due to invisible refilling convinced me to shut the valve to my autofill permanently. The effort to drop a hose in the water periodically is minimal considering I have a faucet and hose a couple of yards away from the pool edge. I do not live in a high evaporation climate so an autofill had limited benefit for me.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Mar 2013
    Yucaipa CA
    87
    You could use a sprinkler anti-siphon valve along with a solenoid in the normally closed position. When off the sprinkler valve would drain the line when it shuts off to keep contamination from getting in the domestic water line and then solenoid would keep water from back flowing into the line. Using a float switch you could turn both valves on when to water gets low. But all that would be quite complex and leave open for areas of failure but most failures would just make nothing work at all.
    Or you could do something quick and cheap like this.
    http://www.scienceprog.com/the-cheapest ... er-filler/
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I too don't like auto fill options as they cover up potential leaks. If my pool is loosing enough water to need water added more than about once per week I want to know NOW.
