Thread: Pool Cover for I/G
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Pool Cover for I/G
    Hey All,
    Looking to buy one of those loop lock pool covers for our rental house i/g pool. Anyone know of a reputable site that sells them reasonable?
    TYIA
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool Cover for I/G
    Check with the folks in the lower left corner of the home page first. I don'y know whether any of them handle them or not. If they don't, check with poolcenter.com. I bought mine from them, and the price was good and they were good to deal with.
    Mar 2008
    Central VA
    328
    Also, check on the installation. You or someone you know may be able to install it, but I had my PB do mine since it involves drilling into your concrete...and it can crack. Plus I think the layout has to be pretty accurate; mine is good & tight but I can see how just a little miscalculation could cause sags or too-tight areas. BUT it is a great cover, I think of all the things we have gotten for the pool, the robot vac and the pool cover are very likely the most time-saving.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Mar 2008
    Evans, GA
    323
    Thanks guys!
    Todd, this is actually a replacement, so the holes are already in the decking and screws I actually still have. We had one before, but it split up both seams and more less dry rotted away, it was old. Then we have the temp HUGE plastic tarp thing for it. NOT GOOD AT ALL! Very messy to deal with.
    *~ Laura ~*
    TF-100 Test Kit
